V6 with high idle, yes another question, but....
Old 04-17-2009, 06:52 PM
Ed in Maine's Avatar
I have been through a lot of threads in my search but I can't figure it out. I am idling at 1,500 rpm after full temp has been reached. It is not AC kick in or PS pump kick in. I think it is the temp sensor, but.... when I push hard on the arm in the idle direction (driving the butterfly) next to the TPS, I can get it to kick down to 1,000 rpm ish. When I remove force, it jumps back up. Do I need to adjust the TPS? None of the vacuume accuators are pushing on the arm with any tension when in idle.
I am considering picking up a used complete throttle body assembly with complete sensors, but do not want to give in that easily!
Old 04-18-2009, 05:33 AM
TNRabbit's Avatar
Check inside the TB to see if there's gunk built up holding the butterfly open.
kazuya2416
04-05-2024 02:17 AM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
ZONAYODA
07-13-2015 07:17 PM
Quick Reply: V6 with high idle, yes another question, but....
