un-needed vacuum lines
Old 07-23-2012, 11:49 AM
parkerst02's Avatar
I have a 87 22r motor i just tore completely down to find the reason for a dead cylinder(no luck besides finding torn vacuum line) while putting it back together it came time to put the vacuum lines back on and i was wondering if there are any that you just absolutely just do not need. I don't need to pass smog or anything and its a pain trying to get all of them hooked up so can i just go and cap off all the small lines or is there some that is needed. Thanks
Old 07-23-2012, 01:20 PM
scope103's Avatar
All of them are needed.
None of them are needed.
They're all there for a purpose. But if you're willing to give up some functionality, you could probably get by without them. You could, for instance, disconnect the power-steering idle-up. You'll kill the engine each time you try to parallel-park, but if you avoid turning the steering hard you probably won't notice it.
The point I'm making is that you won't be happy with internet advice until you understand just what each line really does. Then you can make a useful decision.
Old 07-23-2012, 01:36 PM
parkerst02's Avatar
true but all my trouble is at the carburetor egr valve etc on the intake manifold. And i don't have to worry bout the power-steering idle-up (no power steering)
raptor510
08-19-2015 02:15 PM
Poppie51
07-23-2015 05:03 PM
Poppie51
07-16-2015 06:16 PM
jgwerth
07-16-2015 03:23 PM
TokyoD23
07-12-2015 06:01 AM
Quick Reply: un-needed vacuum lines
