Transmission swap
Old 09-25-2008, 09:47 AM
treegrower's Avatar
Transmission swap
I recently bought a 93 SR5 w/ automatic trans, and find that I get a marvelous 13 mpg ! In my 92 w/ 5 sp I got 18-20 mpg. This 93 has a pretty solid frame, and in the rust belt, that is a significant issue, so I would rather swap transmissions than look for another truck. I am familiar with these swaps in American classics (my other truck is a 57 Chevy w/ 350, and I get 18 mpg), but don't want to assume Toyata swaps are the same. some questions before I start buying things:
Are the transfer cases the same from auto to manual?
Any need to change or modify crossmembers for the swap?
What about drive shaft lengths?
Will I need to change computers, or are there some electronic short-cuts which will be necessary?
Thanks in advance for tips
Old 09-25-2008, 10:17 AM
space-junk's Avatar
theres a blue bar up above your post... 4th link from the left is search...
its an awesome tool to use...
Old 09-25-2008, 02:43 PM
tc
tc's Avatar
Do you have a manual transmission?
It may be easier and more straightforward to regear the diffs down a step or two, as the MAJOR problem with the automatic is the MONSTER overdrive coupled to a relatively peaky and underpowered engine. This results in the transmission not locking up the torque converter or not being able to hold overdrive which dramatically increases your consumption.
Old 10-22-2008, 10:04 PM
toyscraps's Avatar
Funny thing is, when you do searches, half the responses you find are just like this.....
Old 10-23-2008, 03:31 AM
phildelfino's Avatar
OMG...LMAO
Very true though
Liadrin
04-25-2022 02:54 PM
mskalmus
05-28-2017 07:51 AM
jjrbus
07-17-2015 07:06 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Transmission swap
