Towing a Toy that is locked
Originally Posted by rockota
Soem good info here, but... According to Marlin, the rear shaft MUST be disconneted or you will burn out the tcase. The oiling doesn't work w/ the tcase in neutral.
I say drive it, but that's just me. If you tow, pull the rear shaft.
exactly, when the engine is running, it's spinning the input shaft, which slings oil all over the t-case.
when you are flat towing, the rear wheels will spin the driveshaft, but no oil is being thrown around the t-case.
that's why on my 90, toyota recommends up to 30 miles flat tow before the seals go out and further damage will occur.
it's best to disconnect the driveshaft and spend the 30 minutes of doing this and prevent uncessesary $$$ fixing it afterwards...
Right. This is another reason putting the Tcase in 2hi and the trans in neutral works best. Like I said, I can attest to thousands of miles towed this way and no ill effects.
Peevedkitten
11
08-31-2015 06:57 PM
defrag4
07-31-2015 10:50 AM
pyramid
07-30-2015 10:05 AM
