Tires too big?
I also cranked the torsion bars down a bit, they had them cranked all the way, when I went to jack one side up the suspension didn't have anymore travel in it(it was fully extended with the weight of the truck on it) it takes bumps in the road much nicer now, but it barley rubs with he wheel cut to the lock.
We didn't get to go over the old steering types in school, so forgive my ignorance... How do you tell if an idler arm is bad? If there is free play then it's bad?
Check the wheel bearings for play? Make sure both front wheel bearing preload are same side to side, if one is tighter it will pull to that side. My POS
does that currently, never,ever, ever buy a torque wrench from autozone.
it moves up and down before it will turn with the suspension, basically you can grab a wheel and wiggle it, then you look for the part that isn't moving with the rest of the suspension
#25
I try not to buy anything from autozone, but it wanders(one min it will be pulling to the left, then to the right, it's completely random) I think this idler arm will combat the problem.
#26
ok, I traded for some 31x10.50s mud terrains and that helped out in more ways then one, but still the same bouncing and unstableness around 45mph, I seen my idler arm had some play, I replaced that and the thing drives real good now. I just need to figure out what I did wrong rebuilding the carb and I'm set
Up&Down
08-05-2015 06:20 AM
DrZero
18
07-24-2015 11:31 PM
