timing belt
timing belt
Does anyone know the rib count between timing marks? For the 3.0? My belt doesnt have the factory markings, nor did father inlaw mark when removing.
Thanks Sean
Thanks Sean
When you rotate the crank two full revolutions, you're looking for the marks on the cam gears to line back up with the dimples on the rear timing cover. The crank pulley should also be aligned with its mark.
If the marks on the cam sprockets don't line up, you probably didn't get the belt set correctly before you released the belt tensioner. Try again.
