stock tbar vs. downey tbar
Old 07-26-2009, 11:03 PM
joshuapc's Avatar
that sounds like its right and i would suspect that it is. its kinda like when you buy a suspension lift and have to specify between v6 or 4 cylinder. the v6 lift is higher in the front to make up for the weight. if i install stock bars would i have to take it in for another alignment?
Old 07-27-2009, 06:23 AM
RustBucket's Avatar
Stiffness of a cylinder is torsion scales with diameter to the fourth power. The 26mm bars should be about 70% stiffer than the stockers. OME bars are only 11% stiffer.
Old 07-27-2009, 11:20 PM
joshuapc's Avatar
wow it sounds so legit when you put it into numbers!!
Old 07-28-2009, 04:32 PM
FredTJ's Avatar
Yup, a little makes a big difference. All the "work" is done by the outer part of the bar. On the Sprint cars we run hollow bars as the "extra " material in the center does virtually no work and it helps to keep the weight down.
Fred
Old 07-28-2009, 06:54 PM
  #25
joshuapc's Avatar
wow that sounds pretty innovative. stock it is!!!
Ktm526
10-07-2015 05:14 AM
Daenerysdad
10-01-2015 07:33 PM
Pocoyota
09-08-2015 02:41 PM
AkitaDog
09-03-2015 09:01 PM
DiggnDeep
09-03-2015 02:45 PM
Quick Reply: stock tbar vs. downey tbar
