Stock T-Bars Vs. Downey 26MM. need help with flex.
Old 05-17-2007, 04:21 PM
2WDoffroadx's Avatar
Are the stock Toyota Tbars 23.4mm? I am running Sway-a-way 25mm. I havnt tested the flex. I should try on a curb or something.
Old 05-17-2007, 04:24 PM
881stGenRunner's Avatar
stock are 22.8. the OMEs are 23.4
Old 05-17-2007, 07:40 PM
slosurfer's Avatar
Originally Posted by Sonofmayhem
um cranking the bars takes away from uptravel right? so to get the same height wouldnt you crank the stock bars more and get the same ☺☺☺☺ty uptravel?
That is what I was thinking. Plus I think 4runners look good with a slight forward rake to them. Also makes them sit pretty level once loaded. I say try the stockers and maybe just a slight crank to them.
Old 05-17-2007, 07:57 PM
aight, will im pretty sure i will, but will i need an alignment?
Old 05-17-2007, 08:02 PM
  #25
slosurfer's Avatar
Yep, even if you switch tbars and crank to the same height, I doubt it will be perfect, so you would need an alignment anyways. Or you could try the do it yourself alignment I am pretty sure elripster has a writeup on how to do it. Might be worth trying if you are short on $$$
Old 05-17-2007, 08:04 PM
  #26
okay. Ya i tried reading a DIY alignment thread earlier and i just got lost. money really isnt a problem right now so im gonna get it aligned. Plus i have wheeled it pretty hard the past 6 months i have had the lift and i dont think another alignment will hurt.
Old 05-17-2007, 08:29 PM
  #27
There was a thread about Do it yourself allignment.
i cant remember where it was, but its YT. look it up
Old 05-18-2007, 01:23 PM
  #28
86Original's Avatar
The smaller (stock) bars will travel farther given the same load. So if the rim-to-fender distance is the same as with the Downey bars, the suspension will flex more. In addition, if you think through all of the pivot points and lever arms, you are not changing any of the geometry that affects the alignment if you only change the T-bars and set them so the rim-to-fender distance hasn't changed when sitting on the ground. Pretty sure the rest of the engineers on this forum will agree with that assertion. HTH.
Old 05-19-2007, 06:58 AM
  #29
thats exactly what i wanted to hear thanks for the help everyone!
Old 05-19-2007, 07:50 AM
  #30
FredTJ's Avatar
Another way to put it is that the smaller the diameter the bar the lower the spring rate.
Fred
Ktm526
10-07-2015 05:14 AM
Daenerysdad
10-01-2015 07:33 PM
Pocoyota
09-08-2015 02:41 PM
AkitaDog
09-03-2015 09:01 PM
DiggnDeep
09-03-2015 02:45 PM
Quick Reply: Stock T-Bars Vs. Downey 26MM. need help with flex.
