Stock 2nd Gen 4Runner Buildup plan
high pinion refers to where the pinion shaft enters the differential and also determines the direction of rotation of the ring gear- high pinion turns the opposite direction of a low pinion... unless the ring gear is on the opposite side of the pinion gear.
You dont need a hi-pinion 3rd. Thats only really needed in the front axle of a sas'd truck. Even then its not always neccesary.
Install your body lift first, then you can build all your armor around that. Sliders will be easier to install with a body lift You can also do a engine/drivetrain lift and have a flat belly! That would be great for clearance.
#25
Hey y'all. I recently got a 94 4Runner with the 3.0 and 5speed. It is in decent shape inside and out. I won't be making this into an SASed rock crawler right now, but untill then I need some pointers for a build up. I already got a K&N air filter(lol...good start). Due to school, my funds are limited, but I will have about 900 buck in about a month or two.
I'm thinking about starting with a ProComp 4" lift, but I just bought a new set of 31.10.50 KO's so it will look kind of gay unless I can sell these and buy a new set. Was thinkin about just doing that block kit that 4Crawler.com has for about 2 inches. But I will need new shock(?) for that and I just bought a cheap stock set from Napa.
What do you guys think I should do and where should I start?
Thanks,
Percy
Thanks,
Percy
- rear Aussie locker $250
- OME rear coils (level it out) $150
- OME shocks $350
- BJ spacers and alignment $200
- swaybar discos $50
That's $100 overbudget, but perhaps you can sell your body for an evening or something.
Screw the lift until you learn to drive the truck.
#28
Could you give me some hints on where some good places are to find those parts? Is it possible for me to install that locker. I do have some experience with Dodge 3rd members.
#31
$900 would break down nicely along the following lines:
- OME shocks $350
If you want to keep your v6 3rd, run a lockright.
#33
I have a 93 4Runner. I'm about to install OME-901 coils and N72F shocks on the rear and the BJ spacers and N98s on the front. In the near future I plan on instaling ARB air lockers front and rear, then either build or buy front and rear bumpers and sliders. Should I continue to run the stock 31x10.50s? Or should I eventually move up to 33s?
06-01-2021 01:51 PM
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
