She is ticking :(
Old 02-25-2007, 07:48 PM
yotawheelin95's Avatar
She is ticking :(
So i got done putting 1100 miles on my truck, all highway and now the 3vze is ticking on me, i know i need to do a search for why, lifters i think, but i just need some comfort since up here im surrounded by ford guys, how serious is this, and anyway i brought my ford buddy down to meet the family and while we were down there BLIZZARD! so we had some fun tooling around in the snow snow drifts up to my hood, and still made it through, the ticking just started off quiet but now i hafta turn the radio up in order not to hear it, its very annoying, what do i do to fix it? it doenst seem to be affecting the power, and i feel like im whining over nothin but no problems from when i bought it 120k and now 148k i should be easier on her but its so fun
Old 02-25-2007, 08:08 PM
ChickenLover's Avatar
Take a look at your steering shaft seal. It is not uncommon for that thing to wear-out and leave a hole directly into the engine compartment. Letting all that normal engine noise into the cab.
When I first got my runner, the ticking noise had me baffled. I finally noticed the worn shaft seal and replaced it. No more ticking.
Click here to see a pic of what the seal is supposed to look like.
Old 02-26-2007, 11:15 AM
faubrunner64's Avatar
definitaly check your steering shaft boot
Old 02-26-2007, 03:43 PM
PabloA's Avatar
I had this same problem, I even did the same as you and replaced the steering shaft insulater. The problem is not the valves eigther, I know that because I had the valves adjusted, the problem is most likely the timing chain guides. Take off your valve cover and you can see whether the chain guides are worn out. The ticking is the timing chain rubbing against the aluminum head.
I learned this problem from someone on this site, but I forgot who.
Good luck, give us an update.
Old 02-26-2007, 03:48 PM
He has a 3VZE.
Old 02-26-2007, 04:21 PM
Brenjen's Avatar
No chain, it's a belt.
Old 02-27-2007, 12:16 PM
PabloA's Avatar
oops, sorry
Old 02-27-2007, 03:37 PM
pruney81's Avatar
Valves or injectors but, most likely valves
Old 02-27-2007, 06:20 PM
Victor's Avatar
Toyotas of this vintage are notorious for noisy injectors. I'm so used to mine I think I would worry if it wasn't ticking!
Old 02-27-2007, 06:25 PM
Toyota D's Avatar
i have the same noise with mine its soo annyoing. i heard from somewhere on here that the seafoam stuff works. i haven't tried it yet, but its supposed to clean it up.
Old 02-28-2007, 04:11 AM
cormel's Avatar
This is most likely your injectors. Over time the infectors tend to get louder as they get older. Mine does the same thing, just something I've gotten used to. Try seaform, alot of people swear by it.
Old 02-28-2007, 06:22 AM
AuburnRunner's Avatar
Is it a possibility that you have an exhaust leak?
Old 05-02-2007, 11:56 AM
I was thinkin exhaust leak. its getting louder so im not sure. Im gonna try the seafoam. to see if it is the injectors. No real loss in power but very loud and annoying. sorry forgot to subscribe to my own thread
Old 05-02-2007, 02:33 PM
Kiff's Avatar
I seem to have a similar issue, but only happens when the engine is warm, so that should rule our cracked exhaust mani, or leaky gasket. I seafoamed the motor and no difference in tick, did my valve laches, all were withing spec and I fixed 1. Still same tick, at all RPM's and loads.
Davebarbier
11-03-2015 03:28 PM
kawazx636
09-29-2015 08:22 AM
Tacoma1313
09-15-2015 07:51 AM
ErikZ1220
09-10-2015 04:53 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: She is ticking :(
