Scary Video of my 3VZ-E Oil Pressure
I use amsoil 10w40 in my 3.0 due to a low reading.This brought it up to normal at idle.
http://www.amsoil.com/storefront/amo.aspx
I have to same issue with my 3.0, i rebuilt it and now the pressure is just as yours. tried a 10/40 and it helped but i went from 12.5 to 10 mpg. so back to 10/30. she dont idle much but stay about 10 psi, goes to 40 at rpm. gonna have to check my relief valve. was a brand new pump...
Dredging up an old thread, can a person get to the oil pressure relief valve without a lot of work? I have low to no oil pressure even with a mechanical gauge and looking at the pictures I can not quite tell. Reading the manual with a 4 x 4 the front differential has to be pulled. Might put it at the end of the drive and sell it for parts the truck has over 175,000 miles on it.
#25
When you put the mechanical gauge on the engine, where was it connected?
The stock oil sensor wires are notorious for shorts that cause excess resistance & thus low readings.
#27
Odin
07-15-2015 09:28 PM
88yodabasket
07-13-2015 01:32 PM
