Replaced O ring on oil cooler
Old 03-12-2006, 06:10 PM
jjenks0's Avatar
I just got done replacing the oring on my oil cooler. It was leaving quite a pubble of oil on the driveway. The oring cost about $6. It took about 2 hours. I jacked up the front end and took off the drivers side tire. Put a jack stand under the frame by the drivers door. I was able to unhook the bottom hose by reaching up underneath behind the engine. I could not get the top hose loose due to old age and it was stuck on the fitting. So I loosened the center bolt with a cresent and remove the oil cooler from the block. I was then able to bend the hose back and work a screwdriver inbetween the metal tube and old hose from underneath again. Got it cleaned up put some grease back on the new oring and tightened the bolt with a 10"cresent. I would have liked to have torqued it but could not get the wrench up there. A test drive showed no leaks. Keep my fingers crossed. It is not that big of a job for those of you thinking about doing it. The oring is a buy from the dealer.
Old 03-12-2006, 07:50 PM
rpeAMP's Avatar
Hey thanks for the post...good to know.
I will be doing this soon so I will definitely reference this post.
Old 03-13-2006, 04:14 AM
jjenks0's Avatar
Good luck! I actually thought it was a bigger job then it was.
Old 03-14-2006, 07:43 AM
VA_Yotaman's Avatar
I bought the O-rings about a month ago, and haven't installed them yet. In preparation for the job, I cleaned around the cooler and oilpan really well with Gunk. It was so clean, that I thought that I would leave it be, and confirm exactly where the oil was coming from before I took the time to do the O-ring replacement. To date, I have no fresh oil drips/seepage. I guess all the buildup was from unscrewing the oil filter. I guess the ol' 3.0 is burning it. Time to change to 10w-40 I guess.
Old 03-14-2006, 07:48 AM
snap-on's Avatar
there are 2 seals on the oil cooler.
an o-ring thingie on the huge like 28 mm nut and a weird looking gasket/oring thingie between the cooler and the block.
I bought both as the seal in the back was leaking on mine. but in the process now the oring is leaking in the front (just not as bad) <grrrrrr> I think i forgot to take the OLD oring off the bolt before i put the new on one.....
i used a socket on an extension and an impact to run the nut off. i didnt want to risk rounding it off...
Old 03-14-2006, 06:03 PM
jjenks0's Avatar
I did not know about the seal around the bolt untill I got home. So far the old one is holding up.
bigjstang
08-25-2021 12:41 AM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Gamble_STi
07-07-2015 07:54 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: Replaced O ring on oil cooler
