Rear Heat Removal ????
Old 11-22-2008, 06:41 PM
swerks's Avatar
Question Rear Heat Removal ????
My rear heat does not work I would like to replace the extra pluming. Is there any write ups or any help would be appreciated.t his is on an 86 turbo 4runner
Old 11-22-2008, 06:47 PM
874runnersr5's Avatar
If my 87 is the same as yours for rear heat, all it is a blower/fan under the center consol. It unbolts after you remove the center consol
Old 11-22-2008, 06:53 PM
swerks's Avatar
I want to remove the hoses that supply the heat. I need to know whats involved and which hoses need to be removed and plugged.
Old 11-22-2008, 07:02 PM
leebee's Avatar
supply and return lines from the valve on the firewall down to the tunnel and coming up near the tcase. you can remove them completely or cut and loop at the valve on the firewall.
remove your console, remove the blower assy, reinstall the console and youre pretty much done.
lee
Old 04-09-2009, 05:47 AM
swerks's Avatar
finally getting around to tackling this project are there any new parts needed to make this go smoothly ??? any more info would be appreciated. I am more concerned with the plumbing than the blower in the counsel itself.
Old 04-09-2009, 06:18 AM
tj884Rdlx's Avatar
get to the firewall, do a quick measure, and go to napa or similar and get a little c-shaped heater hose, so you can loop it back on itself. a couple clamps and you're done. this is the easiest way i've found. plus, if you want to go to 4crawler's website, you can check out his hot shower mod!
link: http://www.4crawler.com/4x4/CheapTricks/Shower.shtml
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
Iceman4193
07-15-2015 04:48 PM
icentropy
07-14-2015 10:23 AM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Rear Heat Removal ????
