Rancho Upper Control Arms
Old 01-12-2009, 03:23 PM
  #61
flashkl's Avatar
smart steering stabilizer mount, never seen that before
Old 01-12-2009, 03:26 PM
  #62
sincal's Avatar
They should work though.. I dont know about small size though... compared to mine there huge..let me look through my downey mag real quick to see if i can find anything
Old 01-12-2009, 04:23 PM
  #63
iamsuperbleeder's Avatar
it would appear Downey does sell them separate
the $200 may be worth knowing their built right, and not having to mess with the trial and error of fabing them up
but lets see it there's other options too...
oooh, and I see some nice tie-rod sleeves there too
Old 01-12-2009, 04:29 PM
  #64
sincal's Avatar
I knew they did but couldnt find the part number..lol well yeah Its better than fabbing them up, and I wheel my yota moderately and not a problem so far. I need new shocks but thats after three years
Old 01-12-2009, 04:31 PM
  #65
hahaha, you need new shocks? mine are original with 292k on them!
yeah, feel's like I'm at sea while I'm driving
Old 01-12-2009, 04:36 PM
  #66
sincal's Avatar
LOL mine are just stiff. been through some rough terrain i guess..lol they worked well..lol Im thinking of just getting some cheap O's for the mean time. I have the torsion bars down to the max with all new ball joint tie rod ends and pitman arm and just so damn stiff. So im pretty sure the shocks are toast.
Old 01-12-2009, 04:40 PM
  #67
are you running stock t-bars, or the Rancho ones?
I bought the Rancho ones with the arms, but I don't know if I want to use them if they're stiffer than stock...
Old 01-12-2009, 04:45 PM
  #68
sincal's Avatar
No I have the stock ones. Yeah the Rancho ones would probley be way worse..lol dont know if my teeth would stay in my mouth from the ride..
Old 01-12-2009, 04:50 PM
  #69
if they would be anything like cranked stockers, then I wont use them, lol
Old 01-12-2009, 04:51 PM
  #70
sincal's Avatar
yeah i had mine cranked for awhile till i got the ball joint spacers.. then had to loosen them up due to binding in the cv
Old 01-12-2009, 05:25 PM
  #71
BLKNBLU's Avatar
but I don't know if I want anything on my truck that says "Ford"
How much would "Ford" bother you? Those shock towers are about $13 each. A far cry from Downey's $178.
Old 01-12-2009, 05:40 PM
  #72
BLKNBLU's Avatar
They are likely to be stiff. There are a couple of threads about the different size T bars on YT somewhere but this is the quickest one I found.
https://www.yotatech.com/forums/f31/...nd-gens-68897/
Post #6. If they are in fact 25mm, they are going to be a poke in the eye. The Sway away ones are also 25mm and are pretty universally panned as too stiff. I'd stick with the stockers. My .02.
Old 01-12-2009, 06:29 PM
  #73
yeah, that's what I was thinkin; that they would be thinker and net a more harsh ride
the stocker's will do just fine I think
I don't think I'll leave them all the way relaxed though; I may have to raise them to match the rear. In the back I have WabFab 3.5" shackles and I'm going to also be installing some 2" springs probably, so I think I'll net close to a 4" lift front and rear while keeping a decent ride, not to mention a little more clearance once I make the room to tuck 33"s with ease; that's what I'm going to shoot for anyway, I think it'll work out
I have too many plans... this, then tires, then gears and lockers, unless I do the MC font and bumper before that... I have a long road ahead of me, but it's going to be so much fun!
haha, you have a point...
Old 01-12-2009, 09:45 PM
  #74
sincal's Avatar
Trust me you will fit 33's just fine. That is what im running without the shackles in the rear and with the t-bars relaxed all the way. I just am waiting to regear to 3.88 these 33's suck trying to get up hills. Im literally toped out at 35 mph. But soon will change
Old 01-12-2009, 09:58 PM
  #75
scuba's Avatar
Downey has a catalog..? and sells more stuff..? Ill look into that
Old 01-12-2009, 10:07 PM
  #76
sincal's Avatar
They sure do. You have to send them five dollars for it but they got one.
http://www.downeyoff-road.com/Catalog/index.htm
Old 01-14-2009, 03:07 PM
  #77
I may have to buy one, thanks!
Downey really needs to take paypal though... so much easier...
And I got my tracking info; they'll be here next Tuesday; I'm so excited
Old 02-07-2009, 02:32 AM
  #78
julienade's Avatar
i just got a set of these rancho arms also.
and they didnt come with the shock towers either.
do i need to get the shock towers or a diff drop?
i also have a set of 1.5" bj spacers that i plan to put on.
and what about those tie rod sleeves?
any pics of your progress BLEEDER?
Old 02-07-2009, 09:38 AM
  #79
well, absolutely no progress so far it's killing me having the parts ley on my floor, but I'm still needing aditional parts, and the time to do it all
The Rancho UCA's did not come with new shock towers as far as I know, ony becuase of the fact that they, installed by their self, did not require it. The installation of them also does not require a diff drop.
HOWEVER, doubling the lift the UCA's will give you by adding BJ-spacers with them, installing a diff drop and taller upper shock mounts will benefit greatly:
The diff drop will keep the angles of the CV's down, keeping them from binding up, and prolonging the life of both the CV joints AND the boots around them
The taller shock mounts will allow for the installtion of longer shocks to provide room for more travel (more droop than compression probably).
So to further answer you question, you could in fact install either JUST the UCA's, or JUST the BJ-spacers, with no other mods needed, and everything will be fine.
Old 02-07-2009, 11:25 AM
  #80
julienade's Avatar
ok thanks
i was thinking about ordering a bracket lift and stacking them all together
and maybe some sway away or downey torsions
depends on the ride
what about those tierod sleeves?
do i need them?
Quick Reply: Rancho Upper Control Arms
