Rancho Upper Control Arms
#41
I've seen some slip-yoke styles somewhere before, I'll just have to find them again; or fab some up
IIRC, there was a thread on here not too long ago where the poster had them and managed to find the replacements I believe, but I can't remember who manufactured them...
EDIT:
found the thread
https://www.yotatech.com/forums/f116...v-axle-161173/
could maybe fab something up like that... we'll see... if I could get the flange that bolts to the diff milled, the rest would probably be easy
#44
Ahh, so Downey still might be selling them. I may have to go ahead and pay for one of their catalogs (since they sell much more than they show online)
#45
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
#47
yet another obsticle I'm going to have to overcome...
EDIT:
found the thread
EDIT:
found the thread
#49
There is no need to worry about the spacers. I installed mine with same rancho a-arms and there is not a problem at all. The only thing is I had to realign of course, relax torsion bars a bit and do the diff drop. I really didnt need to do the diff drop but at full droop the cv angles were pretty steep, so did it as a precaution.
#51
so nobody makes these upper control arms anymore? if so super bleeder when you get them can you get some measurements and some more pics for me i may be able to get some made my buddy owns a fabrication shop.
#52
#53
that would be kewl!
every little bit of info will help on this not-so-common setup
thanks!
#54
Well i took some real quick photos for you hope this helps. Let me know if you want some shots in particular.
The A-Arms With Ball Joint Spacers.
A shot of the trucks Height with torsion bars completely relaxed.
#55
fantastic photo's man!
that's a sick looking truck; that long roll-bar is mean look'n!
a few questions...
1) did you custom fab your upper shock mounts, or purchase a weld-on kit somewhere?
2) what's your steering linkage setup? is it factory with just longer tie-rod sleeves? where's you get the sleeves from?
pics of those two in particular would be awesome as well
thank you man, those are awesome!
a few questions...
#56
The upper shock mount was purchased with the kit that had the a-arms. Would be pretty simple to make i suppose.
As far as the linkage goes im not sure, honestly. I will take some more pics be right back.
#57
sorry about all the crappy pics. This is all with my phone. And a little dirty underneath.. oh well. Hope this helps..let me know what else while im home
Shock Mount
Driver side
Passenger side
Shock Mount
Driver side
Passenger side
#60
it's all good, those will help out a lot
check this out, this is kinda interesting; check out the shock-mounts this guys used on a SAS... looks like it could worn on IFS do to it's small size
http://www.4x4wire.com/toyota/tech/dana44/suspension/
but I don't know if I want anything on my truck that says "Ford"
