Question about Coil Resistance -Ohms
Old 03-14-2007, 05:15 PM
Marc's Avatar
Was wondering if anyone can help.
FSM indicates Primary Coil Resistance (Cold) should be between .36 and .55 ohms.
I've checked 4 used coils 3 of which work and 1 of which doesn't and they all read .7 ohms.
Anyone else run into this?
Old 03-14-2007, 11:28 PM
motoriderbc's Avatar
Ohm testing of most automotive circuits is basically useless. The circuit needs a load on it (ie amperage) to test it's integrity. The best ways to check a coil is to a) current ramp it b) Ignition scope pattern c) spark tester. The resistance check is only good for checking to see if the coil is completely shorted or open. Most coil failures are due to weak insulation internally, but the insulation doesn't break down till several hundred volts are built up.
Old 03-15-2007, 06:54 AM
isaac338's Avatar
Did you check the resistance between your meter leads? My $20 walmart meter has about .5ohm between the leads, which you have to account for in your testing.
Old 03-15-2007, 12:23 PM
Marc's Avatar
This confirms what I suspected. The ohms test sucks, considering my known bad coil checks out ok.
Good thing I have lots of coils to throw at it.
sandyota
02-04-2021 11:16 AM
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
Numberonedad6
07-30-2015 07:10 PM
konah
07-30-2015 02:08 PM
Quick Reply: Question about Coil Resistance -Ohms
