Overheated axle shaft?
Old 09-06-2010, 05:37 PM
the_supernerd's Avatar
I am replacing the wheel bearings on an '86 4x2 axle. After getting one of the shafts out and inspecting it, I noticed a small ring of blue color between the dust seal and the wheel mounting flange. It seems too far away from the wheel bearing to be cause by that. What would cause that? Could the truck it came out of been overloaded enough to stress the axleshaft? I am mainly wondering if it is safe to re-use or if I should get another shaft.
Old 09-06-2010, 05:50 PM
Here are some pictures of it.
Old 09-06-2010, 06:44 PM
Exiledbikr's Avatar
Clean all the grease off of it and see if it is still there, i might just be from the type of grease that was used, and is there any grooves of any kind? if not id say it should be fine
Old 09-06-2010, 06:53 PM
rebelrunner's Avatar
It'll be fine.
Old 09-06-2010, 07:08 PM
BrianJE's Avatar
I agree Its fine. Use it.
Old 09-06-2010, 07:29 PM
trfytoy's Avatar
Could be from the process of making the axles. Not from the wheel bearings so run it.
Old 09-06-2010, 10:18 PM
iamsuperbleeder's Avatar
you tempered it; it's stronger now
okay not really, lol, I dunno...
should be fine, I wouldn't worry at all about it
Old 09-07-2010, 05:02 AM
RustBucket's Avatar
Looks like heat treatment. I rebuilt a CV last week and it had sections that were blued like that to make certain surfaces harder and wear resistant.
Old 09-07-2010, 05:48 AM
It does kind of look like heat treatment. Thanks for all of the input. It sounds like it should be ok.
A2theK
01-10-2016 10:18 AM
Jcrawl94
10
10-24-2015 04:34 PM
4x4-runner
08-30-2015 08:55 AM
88sasturbotoy
08-11-2015 01:56 AM
ripp96
07-25-2015 02:32 PM
Quick Reply: Overheated axle shaft?
