No low beam lights on my '93 4Runner!!!
The low beams on my '93 4Runner stopped working. High beams work fine in forward and back positions. Fuses under hood are all good. Could the relay next to fuses under hood be the problem? Maybe the switch lever in the steering column? Don't know where to look first. Anyone else had this problem? All suggestions welcome.
Bryan
Bvipers@aol.com
Bryan
Bvipers@aol.com
low beams fixed!!!
I have to admit that I was pretty skeptical that both bulbs would burn out at once - they're both pretty new Performance Products Xenon 100/80W. Well, they were burned out only a year after installation. The factory 65/45W still work and are back in. I guess there's a lesson here...
Thanks all for the help. Just glad I don't have the steering column/switch torn down right now.
My high beams stopped working. They had a delay in them when dimmed from low beam to high for a while but now high is gone all together.. I found a thread on here about tearing the column apart and cleaning something or another.. but I'm just gonna leave it be.. I can pull the lever back and get high beam as long as i hold it.. thats enough to make another driver dim theres
Scotttekoch
23
11-01-2021 12:41 PM
Jnkml
07-06-2015 01:20 PM
