Need fuel line part number
I need the part number of the fuel line from the tank to the fuel filter. 95 Ext cab dlx 4x4 v6. I have been to the dealer and they couldn't get the part right.
I was trying to change the fuel filter and the back nut turned about 1 1/2 turn then froze. Couldn't get it to go either way and rounded the nut. Cut the line and now I can't get the part from Toyota without knowing the number. I was given 7725135660 which seems to be the line from the filter to the engine. (May need it!) The drawings at the dealer leave alot to be desired.
An afternoon job has turned into 3 days and counting now. I still haven't gotten the filter off!
Got the fuel line all fixed... (long time) and other parts needed due to breakage of the output pipe of the fuel sending unit.
The part numbers:
23206-35206 - Bracket S/A, fuel pump.
77252-35240 - Fuel line (From the filter towards the fuel tank)
23300-65020 - Filter assembly fuel
77251-35660 - Tube fuel main/tank to filter/ (from the filter towards the engine compartment)
About $200.00
1995 4x4 ext cab v6 dlx manufactured 11/94
It took about 5 different people at 2 Toyota dealers to get the correct fuel line from the filter towards the tank.
The part numbers:
About $200.00
Avenged
07-09-2015 07:55 AM
Vargntucson
07-04-2015 12:15 PM
