manual swap checklist
Old 07-27-2009, 09:57 PM
smellyvision's Avatar
This 5 speed swap has been a long process with school and working etc. but anyways I wanted to see if i could get a confirmation that i got everything before i tear into it thiss weekend... Again my trucks an 87 4 cyl xcab and i gotz:
w56 tranny and xcase
Bud built crossmember
Flywheel and the flywheel bolts
marlin heavy clutch kit
pedal assembly
master and slave cyl
shifter
I need hard clutch lines right? Then i can drop that wussimatic and bolt up everything... Just wanna make sure im not opening a can of worms this weekend missing something major.. Thanks
Old 07-29-2009, 04:54 PM
Bumb...
Also anyone know if i can re-use the driveshaft for an 87 thought i read you can...
Old 07-29-2009, 08:14 PM
Flash319's Avatar
Not sure but are the starters the same?
Pilot bearing in the marlin kit?
Old 07-29-2009, 08:19 PM
881stGenRunner's Avatar
measure the length of your auto tranny from bellhousing to drive flange. Then measure the manual. if there is a difference, you will need to get a new driveshaft for it, or buy spacers for your current one. most likely the manual tranny/transfercase is going to be shorter.
get the clutch lines from any 5 speed toyota truck, hardline from the master cylinder over to the passenger side firewall, then about 1 foot or so of soft line, then hard line again down to the slave cylinder.
starters are the same
Old 07-29-2009, 08:21 PM
myyota's Avatar
The starter is the same, but you will also need a pilot bearing and theclutch hard line.
Old 07-30-2009, 01:02 AM
Jay351's Avatar
IIRC you need the d-shaft from the manual truck. They are different lengths..
Old 07-30-2009, 05:00 AM
waskillywabbit's Avatar
I got a thread about swaping to manual.
Wiring is the biggest pita to get everything to light up again correctly and the starter safety junk bypassed.
Old 07-30-2009, 06:20 PM
Hey thx for the input i got the clutch lines, now need the man driveshaft so won't start this week will be lucky to next probably, but does anyone know what seal i need for the tranny to go w/ the transfercase? being that their apart.... I work sixty plus hours a week so i prefer to buy online
Old 07-30-2009, 06:22 PM
Toyota RED FIPG and Toyota gasket
Old 07-30-2009, 06:32 PM
Thanks for the quick reply
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
keithporter83
07-24-2015 07:37 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
tobylab
Diesel Swaps
07-17-2015 06:51 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: manual swap checklist
