Main Ground Fell Off, Blue VSV, and AFM questions
I took the fuel line off the filter and cranked it and fuel shoots out. its getting fuel, its just flooding out, i was told the AFM could be the problem if its just broke inside.
How is the air? I ask because a while back a friend had this issue and his darn air filter was about 90% clogged and it did the same thing yours is doing. Had great spark (the "weenie near the fender when I grabbed the plug wire" test confirmed that *ouch*) smelled fuel but wouldn't start. We opened the air box and pulled the filter and when we saw how bad it was we tried it without the filter in the way. I don't recommend driving it like that for obvious reasons but it did fire the first time and run fine. New filter and he was good to go.
Might be an easy fix.
#25
An engine needs 3 things to run: air, fuel, and spark.
It sounds like you have fuel.
Your working on the air problem.
What have you done about the spark yet? You say you have "hot spark", but what does that mean? I would go through your ignition system too...
Let us know what you find out.
#28
I have gone through the ignition system, everything in it is new besides the coil. distributor and everything, it worked fine til one day it just quit.
#30
** blue VSV connection.
My 88 truck fails to start floods itself out, i have just discovered a broken blue VSV vacuum, would this cause it not to start??
it is the blue valve on the vacuum system which bolts to the valve cover.
feels like it goes to the back of the fuel rail on one side.
wahts it do? and since its broke is that why my truck floods out?
#34
I guess it's possible your AFM flapper is stuck closed. Mine was stuck open and the engine ran super rich, coughing black smoke. I removed the air outlet hose, the electrical plug, and then just un-snap the 4 clips and it comes right off. I wiped mine out with a rag with some carb cleaner on it. I didn't want to spray anything in there. Make sure the flapper moves freely. 4Crawler has a nice write up on testing it.
#36
Rusty - man I have posted all over your threads today. Anyway, there is a vac line that runs to the fuel pressure regulator. I believe more vacuum (at idle or low throttle) should lower the fuel pressure, and less vacuum at wide open throttle should allow higher pressure. I have heard of people bypassing the VSV and going straight to a vacuum tap on the manifold. You could try that and see if it changes anything. I believe I do have an extra one of those off an 89 22re if it turns out to be the problem.
#40
I'm not convinced you have an AFM problem. The engine will still try to fire even if the AFM is kaput (that's assuming the AFM isn't stuck in wide open throttle causing massive flooding). The wet spark plugs are saying the computer is working and that it wants to give it fuel.
Did you check for spark? I'm going to guess the igniter on the coil is bad or not connected properly. Also, did you check to see if your ECU is throwing codes?
