Lost Brake fluid
Old 04-13-2007, 06:11 PM
Lost Brake fluid
My brake pedal sinking when I hold it long. I kept refill new fluid every 3 days.
I couldnot find any leak in front or rear brake. If Master cylinder's fluid leaked into booster, can the fluid damage the booster ?
Old 04-13-2007, 09:01 PM
longhungsilver's Avatar
Yes it can... Did u check at your break peddle where the rod pushes into the master cylinder?? any weaping around there?
Old 04-13-2007, 09:17 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Could be just an internal leak in the master cylinder like a damaged seal. Try bleeding it to see if it changes anything. Just don't press in all the way on the piston until it bottoms out. That will damage it, if it's not already.
jasonty
41
12-23-2018 01:00 PM
fountain
12-31-2015 06:08 AM
JHalcyonM
08-04-2015 01:19 PM
Poppie51
08-02-2015 11:29 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Lost Brake fluid
