Lockright Problems
Old 05-25-2009, 07:09 PM
yakamoto1988's Avatar
Lockright Problems
So I just got a Lockright for my truck. I installed it in a third member from a 1984 pickup with 4.10 gears and then put it in my 2wd pickup. Everything fit in real nice with no problems. I then take it out and drive it around it seemed to run smoothly. I took it for a few runs down the road, gravel road, and on the highway. I really notice the extra traction, but it seems to be acting like a spool. I hear absolutly no ratcheting when i do u-turns, I just leave black marks on the pavement since both tires seem to always be turning at the same speed. I am confused, I thought that the lockright was supposed to unlock during turns. Any help or suggestions would be great.
Here is the third after i installed the Lockright.
Old 05-25-2009, 07:22 PM
scuba's Avatar
Jack up the truck, have someone hold one tire in place, then slam the other side one way, if it unlocks and turns more without force its unlocking..
I dont really hear mine..I feel it if im in gear..Or I push the clutch in and dont feel it
Are you auto or manual ?
Old 05-25-2009, 07:25 PM
scuba's Avatar
Oh and, The locker will only unlock if it doesnt have throttle, If youve been feathering it with only a little gas through turns thats why...
So try taking your foot of the gas..
Old 05-25-2009, 07:45 PM
I will try that tomorrow after i get back from work. I know that when I was coasting around corners today the truck felt like the brakes were being applied and would slow down quickly, also i could hear my inside tire scraping along.
Old 05-25-2009, 07:46 PM
And I am drivin a 4-speed manual
Old 05-25-2009, 07:56 PM
scuba's Avatar
Deff let off the gas and put it into neutral around a sharp corner..
Good luck and let us know !
Old 05-26-2009, 01:38 PM
highonpottery's Avatar
i just installed my lockright and it WILL click and unlock if you let off the gas and either push in your clutch or put it in neutral. driving slowly around corners with a tiny bit of throttle will make it chug/jump like you have described.
Old 05-26-2009, 02:26 PM
Junkers88's Avatar
What fluid are you running back there? My Aussie (similar to a Lockrite) hated anything thin and synthetic was out of the question. I think I finally settled on 90w-140 so it would unlock around corners.
Old 05-26-2009, 09:04 PM
Jay351's Avatar
I run 75w synthetic. I can get the locker to unlock easily, it just takes the right amount of throttle around the given corner..
however parking lots are the exception
Old 05-26-2009, 10:17 PM
scuba's Avatar
Screw parking lots, people look at me like im an alien driving a ufo..
Old 05-27-2009, 05:57 AM
Junkers88's Avatar
I'm with you there! I love the way folks look at me when I make a sharp turn in the parking lot and the back end starts that "clunk-clunk-clunk-clunk*. UFO indeed!
Old 05-27-2009, 07:14 AM
mrmatson's Avatar
I run 85w 140 with my aussie but I don't know, the lockright might be different.
Definitely jack it up and make sure it is in fact unlocking, if you don't have someone to hold the other tire just jack one side up and leave the other one on the ground and turn the tire that's in the air. It should rotate with little effort.
Old 05-27-2009, 05:22 PM
It is still not unlocking around any turns no matter if coast around the turns or if I have it in neutral. I have a feeling I might know why it is doing this now. I checked through the Lockright box and on the bottom it in the corner i noticed that there was a very small piece of on of the springs in there (probably only 1/5 of the total spring). I am pretty sure that it was one of the larger springs that i found. Could this still cause it to be lock all the time?
Old 05-27-2009, 07:14 PM
Jay351's Avatar
Replace the springs.....
Old 05-27-2009, 07:40 PM
Mic09dcsm's Avatar
But you live in canada so that's important.
bpayne88's Avatar
that little bit of the spring should not matter about the actuation. your locker may just be tight, as was the one i had in my old jeep. although it probably won't hurt any thing i would contact the supplier ar the manufacturer of the lockerand see about a waranty for defect. just dont throw the piece of spring away. as they may want proof of the defect. but like i said it may be tight, and need to be "broken in". done just by driving.
Old 05-27-2009, 07:43 PM
91Toyota's Avatar
shoulda went with an aussie...
SubiKing
08-21-2021 03:57 AM
theking11863
03-19-2016 09:36 PM
Logz808
07-26-2015 07:09 AM
Jonny246
07-24-2015 12:37 PM
kyletbert
07-17-2015 11:39 AM
Quick Reply: Lockright Problems
