LockRight Locker In Front Axle
Don't waste your time with a tru trac, it is a limited slip.
The tru trac is still expensive, and you will have to take your whole third member apart and re-shim the gears.
WATCH THIS VIDEO!!http://www.youtube.com/watch?v=-S2nDDvKHoA
They make two for the 7.5" IFS which is what you have. One goes with the on truck with the 4 cyl front diff, one for the V6 diff.
THey also make a TT for the rear.
There is lots of info on TTs on yotatech.
I think i will just go with the aussie locker, its very simple and it works, im not a hard core wheeler so it should hold up well for me.
#25
The do make a tru trac for toyota 8'' difs, i have a solid front axle in my 86 4Runner, so it will work. this place has them www.casanovaspeedshack.com , they also have them for the cheapest price ive been able to find
#26
here is one for sale on yotatech
https://www.yotatech.com/forums/f11/...locked-151912/
#27
I just did a search on the aussie locker, and i think i will go with it instead of the lockright. from everything ive read so far the aussie locker will have no effect on handling if your driving on the streets, and there is no way that it can if the hubs are unlocked, so the only time your turning radius would be effected is if the hubs are locked.
jerusry
10-19-2015 05:28 PM
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
08-11-2015 01:56 AM
