Installed Air/Fuel Ratio Guage on my 4runner
Last night I unplug it to see if something has change. It actually did. The engine started to stumble. The RPM started giong to 100 to 500 like it was giong to die out but still running. The performance was noticeable. When I hook it back it all went back to normal. Yet I think this give me a good performance boost. I can accelerate better now... I can said that it may give me more mpg gain. I didn't have to step the gas to half and the truck was already moving faster as I have been steeping it pass the half way to the gas pedal... I think this is a good tweak to the ECM? The performance is very noticeable after the install...
But again I think it can depend or vary by truck...
All that gauge dose is makes a little light display to distract you wile driving that's about how useful they are.
If it started running bad when you disconnected it I bet the wiring is damaged from your install and taking it out broke the connection making the truck run bad.
jerusry
10-19-2015 05:28 PM
