idle missing help
Old 02-25-2009, 10:36 PM
kamahaobuilt13's Avatar
idle missing help
hey guys im new hear just looking for answers on why my 92 4x4 v6 4runner is missing at idle and when i drive the motor sounds like injectors idk what it is can someone help me out
note: when start up in the mourning or anytime engine cold it has white smoke out of the tail pipe could it be my head gasket going? also no water in the oil or no need to fill radiator can someone help me out where to start looking
things done cap, rotor ,wires and plugs has all been changed
Old 02-26-2009, 10:16 AM
abecedarian's Avatar
Checked your sparkplugs?
Old 02-26-2009, 11:42 AM
changed all the plugs and wires
but would the plugs cause a miss idle and injector sound when driving??
Old 02-26-2009, 12:15 PM
mmcpeck's Avatar
What do you mean by "injector sound"?
Old 02-26-2009, 12:28 PM
injector sound? you mean a 'tick'?
Old 02-26-2009, 02:16 PM
yes ticking sound noticed oil on the block near the 6 cylinder i gotta do a compression test then from there ill see whats up i think maybe head gasket going?
Old 02-26-2009, 02:17 PM
oil on the block is most likely a leaking valve cover seal.
Old 02-26-2009, 02:18 PM
and a ticking sound could be an exhaust leak or loose valve adjustment
Old 02-26-2009, 03:12 PM
yeah when i got the revs up i dont hear it anymore the thicking noise i mean
Old 02-26-2009, 04:04 PM
also noticed the idle drop when truck running and i take off the oil cap is this normal also when i check the oil with the stick its drops alittle ????
Old 02-26-2009, 04:11 PM
toyota4x4907's Avatar
LOL! Yes thats normal. These engines have the "Positive Crankcase Ventilation" system, or PCV. It uses vacuum to draw crankcase gases back into the intake to be reused. Thats typically why you get gunk build up in the intake area. By taking off the oil cap or taking out the dipstick, you cause a vacuum leak.
Old 02-26-2009, 04:15 PM
Go here
https://www.yotatech.com/forums/f116...-wierd-141477/
Old 02-26-2009, 04:28 PM
oops didnt know that wont do it again tho forsure
still need to know why its missing alittle hummmm
Blamalam
03-12-2022 07:34 AM
icentropy
09-16-2020 02:47 PM
Sleaker
08-26-2020 06:03 AM
TDonkey
07-26-2015 10:14 AM
kyletbert
07-17-2015 11:39 AM
Quick Reply: idle missing help
