Help removing lens from Gauge cluster..Tips on recalibration !
Old 08-17-2011, 03:32 PM
22R88's Avatar
I have a 1988 Toy PU that I need to recalibrate a gauge cluster from a V-6 to a 4 cylinder. Is there a good easy way to remove the clear lens without damaging it. Any other tips to make the swap easier is appreciated.
Thanks,
22R88
Old 08-17-2011, 05:16 PM
slacker's Avatar
the lens is just held in with "tabs" (press fit) .. its always best to disconnect everything so you can pull the whole "cluster" unit out .. then just a flat/spade screw driver to "pop" the tabs out .. and your good to go
Old 08-17-2011, 05:49 PM
john4wd's Avatar
https://www.yotatech.com/forums/f116...w-pics-179106/
Read this thread to do your recalibration...Good Luck....Have fun!!!!
Rasteirinho
11-06-2017 03:40 AM
Esibnitsud
07-30-2015 08:19 PM
Nickyodaman
07-27-2015 12:13 AM
Tyler Cunningham
07-11-2015 10:18 AM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Help removing lens from Gauge cluster..Tips on recalibration !
