Help me with my clutch, it is gone!!
Old 08-27-2008, 08:42 AM
jfly13's Avatar
I just rescently bought an 86 4runner with the 5 speed 22re. I have diven a little and everything works fine. I drove over to Walmart ( I live in the middle of nowhere so that is a 45 mintue trip one way) did my thing, started coming home, stopped at one more place, and then came out to the 4runner to head home and my clutch no longer worked. Luckily I was able to get home by shiifting with the gas pedal, but I am just learninga bought yota's. Teach me a little about the clutch linkage on this thing. I don't think the clutch went out because it was just all of a sudden. Any suggestions. Thanks.
Old 08-27-2008, 08:58 AM
Staff
DeathCougar's Avatar
No clutch "linkage". Its a hyrdaulic clutch.
Your master cylinder or slave cylinder have likely failed.
Old 08-27-2008, 09:02 AM
Fossilized
Staff
dropzone's Avatar
try this link to Online Toyota Factory Service Manuals:
http://www.ncttora.com/fsm/index.html
the first one covers 85-94 4Runners and Trucks. You will find the stuff you need there, after a little searching..it is a 58MB download but well worth it...
Old 08-27-2008, 09:25 AM
YOTABP's Avatar
You might as well replace the slave, master cylinder, and check the lines.
Check the master by taking off the slave and then hold your thumb on the line. Have someone press the clutch pedal and brake fluid should come out with hefty pressure. If you get a new master, do this before you put the slave on to check if its good. I got a "rebuilt one" and it was broke when i got it.
Old 08-27-2008, 09:34 AM
jfly13's Avatar
Sorry, I had a little bit of a premature posting problem I followed the lines, I did not know it was hydraulic, found where it goes into the transmission and that is what blew out. Now I just have to find that part.
Old 08-27-2008, 10:13 AM
CyMoN's Avatar
I bought both the master and slave cylinders from Napa for under 50$
kawazx636
10-06-2021 03:03 PM
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Help me with my clutch, it is gone!!
