Gas gauge reading sporadically or not at all
1988 4Runner 3.0 auto
Tank leaked so I dropped it and had it welded up and lined.
Pickup and pump looked fine
Gas gauge will read full on fill up
After fill up it seems to read ok for a while then next time you drive it zero
It will go back up if you slosh it but it won't stay.
I think that's everything relative.
Any ideas? Questions to diagnose?
:wabbit2:
:wabbit2:
Guessing that the fuel level sensor is outputing level by voltage level. Seeing references for some level sensors for 0-5v, calibrated to 0.25v empty to 4.75v full. So...
What's the volgage coming out of the fuel-level sensor?
Guessing it's 0v or 5v, not 0v to 5v. Also going to guess that the sender either needs to be removed and loosened up a bit, or this specific maintenance event ended it's service life (sometimes just taking it out and putting it back in again is the event to drive it past it's service life...).
Don't have a factory manual, so don't know the proper voltages for testing. Yet if you don't have a variable voltage generator, AA batteries at different voltages should let you build a voltage that tests well. If it's calibrated to 4.5v for full, three AA batteries should get you to around that value.
This post says cleaning the contact area made it work:
http://www.toyotanation.com/forum/10...ml#post3221973
Hopefully someone will chime in with first-person experience.
Yet sounds that it's either going to require cleaning, or signal generation or measurement to identify the broken component.
:wabbit2:
:wabbit2:
gonna hook right on this one. Joe's is edzackary the same. reads full at fill-up and for about the 1st 1/4 tank then is just falls all the way down. we just watch the trip odometer and fill-up in the 200 to 230 range.
but since you are having the same prob....I will see what goes on here.
I just live with the fact that mine dose it but I also have a second sensor that turns on a fuel light when I have only 2 gallons in the tank.
my 86 doesn't have that ask me how I know
How'd the winding on the gauge sender look? Mine did that, and looked ok, but when I pulled it out, and fiddled with it, the wire just unraveled off part of it. So it works til about 5/8ths of a tank, then its all over the place, til about 1/2. Then it usually just bottoms out.
:wabbit2:
On my 22R, many, many, many years ago, my gas gauge would read full, when it was. Then once it would get to about the half-way mark, it would drop to the engine off position, even though I still driving it. I replaced the fuel sending unit in the gas tank and all is fine.
Even though I think all these years, maybe 15 years, the parts gut at Toyota gave me the shortbed sending unit. When the gauge shows nearly empty, I can only put 10-11 gallons of gas in the tank. I seriously doubt I have a 7 gallon reserve.
The sending unit is worn out or the corn whiskey your running in a 50/50 mix with gasoline has taken it`s toll.
once the sending unit wiper gets past the good section of resistor and on the section that is now open it gets no feed back so the gauge just drops to empty .
you know the gauge and wiring is good it is the sending unit that has failed.
I have one here someplace if you need pictures.
Perhaps you can still get a new one??
Is this yours or a victim ??
My 87 4runner has a issue about the same I bought a new sending unit here a few years ago it sits on a shelf with a extra clutch:jessica::jessica:
Filled up yesterday. Good for about 50 miles and it started being squirrely for another 10 miles. It would register up and down from 3/4 to nothing and back again.
Sounds like a bad sending unit. At least I think it can be pulled with little trouble and swapped.
Thanks for the feedback guys.
:wabbit2:
:wabbit2:
