Fuel line question
Old 04-21-2009, 04:29 PM
KYcrawler's Avatar
Fuel line question
Well i finally got a 4runner. I had been previously been wheeli'n early and full size broncos so the metric stuff is new to me. I am replacing the fuel line on my '87 4runner (too many holes and too much rust to fix) and I need to know what AN fitting/braided hose size to order from Jeggs. I also need to know if the AN fittings will couple to the stock fitting at the sending unit and fuel filter. If not, what are my options? Can anyone help?
Old 04-21-2009, 04:49 PM
Banned 'cause I was 4runnerchevy also banned
86toylet's Avatar
You will need adapters to go to the fuel filter (metric Banjo) to -4 AN (minimum, go bigger with the V6 -6AN) then to the tank Adapter -4 AN (min) to toy line (?), all for the Send line (high pressure). For the return you will need the same comming off the rail (I believe its at the regulator Banjo) to the tank adapter.
Crap adds up.
Its been along time so I can't tell you pitch, size and flare *.
Good luck
Old 04-21-2009, 04:58 PM
Flash319's Avatar
I would just get some steel line and use some hose to join to the banjo and the rest. I have had my truck like this for years with no leaks. Just use fuel rated hose and fuel injection clamps. Pressure on these trucks is low, less then 40psi.
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Fuel line question
