EGR Temp sensor code after header install (code 71)
Old 12-04-2011, 08:33 AM
Squeebs's Avatar
atleast i think it was code 71. if my mathematican is right.
Installed a downey long tube header on my 94 22re, now its throwing the egr temp code.
Could it be as simple as a bad gasket on the EGR tube?
And where the heck is the EGR temp sensor?
Old 12-04-2011, 09:20 AM
Squeebs's Avatar
EGR temp sensor is on the firewall side of the intake manifold, right? little dinky thing?
Maybe pull it out, hit it with some electronics cleaner and a tooth brushe and give the threads some new PTFE tape?
Old 12-06-2011, 07:57 PM
Squeebs's Avatar
pulled the sensor, it was covered pretty badly in carbon deposits.
soaked it in seafoam for a bit, hit it with a wire brush, now its clean and purty.
reset the light, plugged everything back up.... now just gotta wait and see.
Old 12-08-2011, 09:37 PM
Squeebs's Avatar
and.... lights back on, same code.
either i shell out 125 bones for a new sensor, or i find a jury rig. ill get back to you all.
thanks for all the help, by the way. haha.
Old 12-09-2011, 02:31 AM
TinMan's Avatar
Put a ten ohm resister in the wiring harness side. It will trick the ECU.
Old 12-09-2011, 04:20 AM
TNRabbit's Avatar
Not 10 ohm; 10,000 ohm resistor.
smiley52
07-11-2015 05:16 AM
Poncho0206
07-10-2015 06:21 PM
Coreyr384
07-10-2015 11:13 AM
Snort
07-09-2015 03:58 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: EGR Temp sensor code after header install (code 71)
