Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
- Toyota 4Runner 1984-1995 How to Replace Ball Joints
Step by step instructions for do-it-yourself repairs
CV, Ball joint, TRE, replacement write up with PICTURES!!
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
If your gonna SAS...then why on earth did you go thru all that?!!? Just for us....? Awww, talk 'bout being a team player.....!!!!!
Great writeup
I'm planning on doing all this and more to my 95 runner in the next month or so. I will do the shocks and wheel bearings while i'm in there. I may even rebuild the steering box too. I would like to put new tires on mine but I guess it will depend on funds availability. I was thinking of doing a writeup also. If you and Scuba can do it so can Hup
#26
Hey superbleeder,
I thought your front end writeup was great! I decided to do my SAS when I am out in Utah for the summer. I have a full garage with welder and all that. My home here in California is not set up to take on a swap. By the end of May I will have all of this IFS for sale. This includes new Energy Suspension sway arm bushings as well as all the IFS crap and rancho shocks.
I will keep you posted if you are interested.
#27
That and after all the above repair/replace there was still a horrible clunking sound. Turns out it is the upper AND lower control arm bushings. I figured, eh, may as well SAS the damn thing.
My idea was to buy a 1st gen and do a complete build and keep my 94 as a hunting/DD rig. After some thought I decided to abandon the 1st gen idea till later and just do up the 94.
#28
Thats what I was thinking.....lol. Just giving a hard time! Like I said, great write up. I'm calling dibs on the Rancho's.....NOW!!!!!!!
#29
OK!
The Ranchos are not even a year old, if you want em 4runnnerfreak they are yours!
I also put new Pro Comp shocks in the rear at the same time. Those are coming off too.
Thanks for compliment!
#32
wow this is great...ill be sure to follow this...with my pickup my shocks and ball joints in the front are goin out so i think it is time to replace all of them....i was goin to go ahead and run a ball joint spacer since i will already have everything apart. but the only question i had is what kind of shock should i get with a 2 in ball joint lift. if anyone has an answer id greatly appretiate it. Thanks ;p
#33
Just an FYI about those Chassis 1 parts; they're available on e-Bay & they suck. I bought some because of the great deal &, even though they were a "deal" they were much weaker than even the autozone duralast parts I had to buy to replace the two lame lower ball joints I received. They're known by their paper thin boots, lighter construction, mild steel, over drilled zerk holes & the list goes on.
Do yourself a huge favor & just buy the Toyota OEM parts...those e-Bay specials fit but are far too weak for a truck.
#34
i was thinking about getting a ball joint spacer when i redo all my ball joints (killing my new tires ....) so i was just wondering what kind of shock you use or recommend me getting...thanks!
#39
I have had quite a few different brands of shocks. And I think at this point I can make a reasonable opinion what is good and what is not so good. This of course is based on what kind of wheeling I do. I do LOTS of off road logging road trail rig wheeling. Some rock crawling but nothing too extreme. I think the Bilstein shock is the best. It is the most comfortable shock I have come across.
I hope that helps.
