cold idle speed adjustment 22re
i did a EFI conversion on the 4runner a while ago, and it consisted of a 86 truck harness, 89-95? upper and lower intake/throttle body, and 85-88 air flow meter (metal filter housing) right now my cold idle is right at 2k, which IMO is a little high, i would like to see it around 12-1500, hot idle is around 700-900, i understand that the coolant lines that go to the TB affect a air bypass, which closes when it gets warmer and restricts air from bypassing the TB, my question is could i "adjust" the max opening of the valve to set cold idle speed, Ive never had one of these apart, so I'm not sure how they work exactly, i figured that id ask here before taking it apart to find out i cant change it, thanks, Joe
Pretty sure its got an adjustment screw on the air bypass thing below the throttle body... I remember seeing something like that in my FSM, but i dont remember what the screw adjusted, seems like cold idle would be about right... try lookin in a FSM at that air bypass and see what it says.
Wow, that's different. Toyota must have incorporated it in the throttle body starting in 86. I thought it was the same setup from 84-88. Glad you figured it out.
