Changing speedometer gear/ A340H transmission
Old 06-12-2011, 09:11 PM
frozenrice's Avatar
I can't find much specific information on whether or not it's possible to check/change the speedometer drive gear in the transfer case for this transmission. I've been wrestling with the "no speedo, odo, mis-shifting, CEL code 42" problems for the last week and a bit. I've changed the VSS, cluster and ECU and I'm still not getting anything and the wiring seems fine so I'm thinking it might be the actual gear inside the transfer case that's gone.
I'm running a 1993 pickup 4x4 with v6 automatic. From what I've read in the FSM so far, if it's similar to the VF1A transfer case for the 22re automatic, I just need to remove the extension housing and rear companion flange to get at it?
Can anyone confirm or has experience with this?
Old 06-12-2011, 10:47 PM
The MAN's Avatar
well if you want to check it, just take the speedo sensor out and get a flash light and LOOK inside the hole... you should see a big worm gear inside it... all you got to do is see whether the teeth are there and not chipped
Old 06-13-2011, 02:22 PM
ATVTRAILRIDER's Avatar
HMM, my A340 doesnt have speedo gears. There is an oblong aluminum thing on the shaft that spins around past the sensor. The sensor itslf is probaly damaged.
Old 06-13-2011, 04:25 PM
frozenrice's Avatar
Pretty sure it's not the sensor. I replaced it with a new one.
The gear I'm talking about is the speedometer drive gear.
http://personal.utulsa.edu/~nathan-b...15componen.pdf
smthwsn357
05-01-2024 07:28 AM
TammyMarie
07-15-2015 11:14 AM
madxman21
07-09-2015 10:26 AM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Changing speedometer gear/ A340H transmission
