Catalyst and RPM question
Old 10-18-2006, 10:24 PM
tomasp's Avatar
Hi. I have posted some pics of my cat converter here :
https://www.yotatech.com/forums/show....php?p=1014694
Does anyone know if it is still good?
Also adding to my question about the >3K RPM performance - I have taken it to 5K today on the hway and it sounds OK, however I am still not satisfied with the performance >3K...
Old 10-18-2006, 10:28 PM
Elton's Avatar
hows it been running since the maf mod ? also i thinks its called a afm
Old 10-18-2006, 11:45 PM
tomasp's Avatar
It is running fine - however at the moment I am running at the stock setting with 4 turns leaner at idle bypass. The reasons I did this:
1. I was replacing my O2 sensor and wanted to test one thing at a time - so reversed to stock AFM setting.
2. Leaned the idle because I spend most of my time in the city idling and figured that should cut on the fuel usage a bit.
Sleaker
08-26-2020 06:03 AM
coffey50
07-28-2015 10:55 AM
91yotapup
07-27-2015 07:19 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
redghost.308
California SoCal
07-16-2015 07:46 AM
Quick Reply: Catalyst and RPM question
