Bleeder letting air into brake system under vacuum
Old 05-10-2010, 07:49 AM
qdude79's Avatar
Been having trouble with pulling to the left when braking, just after replacing both front calipers. Tried bleeding all five valves again, noticed a slight gurgling sound and a little wobble on the bleeder valve on the passenger/front, with only a quarter turn of opening. Makes sense to me that that's where the air's getting in, especially when it pulls to the left.
Question: can I put some sort of teflon plumbers tape or something like that to get the valve to seal properly during bleeding? Will this contaminate the system? Any other "right" ways to fix it? It is brakes, after all...
TIA
Old 05-10-2010, 07:54 AM
Lumpy's Avatar
Well if you just replaced the calipers I'd return the one that isn't working properly.
Old 05-10-2010, 08:05 AM
iamsuperbleeder's Avatar
I thought you were talking about me there for a second...
Old 05-10-2010, 09:07 AM
qdude79's Avatar
Dude, you're the reason I had to ask!
Try searching using the term "bleeder." No workie on Yotatech!
Old 05-10-2010, 09:15 AM
Lumpy's Avatar
I guess that would be a difficult search here...
Old 05-10-2010, 09:27 AM
lmao
sorry
Old 05-10-2010, 12:47 PM
qdude79's Avatar
So, now that I have the attention of a few board Jedi's, I know Lump's idea is the most foolproof, I was just hoping to be able to pull the valve screw, throw some teflon on there, re-install and bleed. Probably a five minute job. Thoughts?
Old 05-10-2010, 01:25 PM
Desp's Avatar
Brake fluid reacts with the teflon tape and eats it almost instantly... it kinda works when there is a ton of air in the system, but it compromises the tape really fast. If you want to try it clean off the bleeder really well before wrapping it.
Old 05-10-2010, 01:57 PM
have you tried replacing the old bleeder screws?
Old 05-10-2010, 02:11 PM
Blue_petersen77's Avatar
Thats my thought. They're only a couple bucks.
Old 05-10-2010, 02:15 PM
hey they don't call me "superbleeder" for nothing
yeah it would be worth a shot; a dealer could probably have them next day'ed, if they don't already have them on hand
Old 05-11-2010, 07:19 AM
qdude79's Avatar
Tried pressure bleeding (g/f pushing on the brakes while I open/close) and it helped, but there's still more drag on the left side than right. Barely noticeable, but there. Gonna run it for a few days to see what happens. No danger...
Old 05-11-2010, 07:57 AM
Make sure your rear drums are adjusted too
Old 05-11-2010, 08:04 AM
qdude79's Avatar
That's a good point, forgot to mention. Rears are good. I'm pretty convinced it's all in the front, as it changed sides when I replaced the calipers. At first, it was so bad that I could "hear" the front/driver's tire grabbing harder (sand under the AT's with the windows down). Better now, but not fixed.
Old 05-12-2010, 08:16 AM
qdude79's Avatar
Alright, I'm still not satisfied that I have a slight pull to the left. Unless anyone has some suggestions beyond bleeding the lines, I'm going to swap out the caliper on the right side. Not a big job, but if someone has an easier "try" to the problem, that'd be great.
Old 05-12-2010, 01:32 PM
Check your rubbers lines to make sure none of them are swelling
Old 05-12-2010, 07:57 PM
betelnut's Avatar
I don't buy this. I've used teflon tape on my FIAT, where, as expected from Italian standards, you could stick your pinky into the gap between the bleeder and the caliper. Worked great with a vacuum bleeder. Here're a few sites that don't state any problem with teflon and brake fluid:
http://en.wikipedia.org/wiki/Brake_bleeding
http://www.nsxprime.com/FAQ/DIY/brakebleed.htm
http://www.type2.com/library/brakes/teflon.htm
Old 05-12-2010, 08:00 PM
betelnut's Avatar
You should also just take apart the right side to see what it looks like. If there's no wobbling feeling in the brake pedal, it's probably not the rotor. In that case, check if the pads are thin or oily, and pull the calipers and pop out the pistons to see if they're rusty or gummy.
Old 05-13-2010, 08:09 AM
qdude79's Avatar
Brake lines are about a year old. Rotors are new. Calipers are rebuilds from Kragen's (just replaced). Pads are plenty thick, no oil.
Think I'm just gonna swap the right caliper. My spidey sense is tingling on that one...
Old 05-13-2010, 08:13 AM
Lumpy's Avatar
Bout time you quit messing about and just do it...
http://www.youtube.com/watch?v=JoqDY...eature=related
smthwsn357
12-04-2023 02:08 AM
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
coryc85
09-09-2015 06:24 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: Bleeder letting air into brake system under vacuum
