Is this on backwards? Trans input shaft seal
I had a leak from my trans. So i pulled it and found oil leak coming from the input shaft. Is this seal on backwards?? This is the retainer plate on the input side of the trans
The spring side of the seal should face oil and the letters should face air. It's been a while since I've been in mine so I can't tell from the pictures and description which side we're viewing from.
Used my quarantine time off to replace the clutch. I hope you guys on this thread are right about the seal being backwards. I bought this truck used not knowing the maintenance history. The transmission input seal looks to be leaking and the seal was on just like the OP’s.
Seal is backwards?
W56B transmission with 89 and later throw-out bearing. Didn’t feel right, and measured much taller than the 88 OEM
All cleaned up with new fork, throw out bearing, seal, collar and clips from 22REPerformance.
Seal is backwards?
The following users liked this post:
RAD4Runner (08-03-2020)
