Any have a write up with pics to replace Oil Pan Seal
I have a leak i think from the oil pan
I need help with pictures any one know any good write ups with pictures because i have no idea what people are talking about when they explain it
also im thinking of making a video for people to help me diagnose the leak
Your oil pan itself doesn't have a "seal", per se. It's held in place by FIPG (Form In Place Gasket) material. I used http://www.permatex.com/products/Aut...sket_Maker.htm on mine. Remove the old stuff from the block and pan with a putty knife and Scotch Brite pads. Then run a bead all around the perimeter.
Replacing the gasket is simple and using FIPG is the proper way to do it. Using a cork gasket can work but is more likely to leak again.
The hardest part is removing what needs to be removed in order to drop the pan. On a 2wd theres no way around it. My truck has a 4" lift so I didn't need to remove any front suspension parts in order to replace the gasket.
There is a FSM in a PDF form stickied at the top of this forum section that explains what all needs to be done.
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
