Aisin Manual Hub Gasket or no Gasket
Old 10-15-2010, 01:49 PM
  #41
Stuwy123's Avatar
Just ordered a set of gaskets and o-ring. $34 for genuine toyota quality.
Can't argue when the hubs still work like new after 23 years.
Old 10-15-2010, 02:16 PM
  #42
JamesD's Avatar
Whoever said RTV is wrong to use is wrong. If your not prepping it correctly it will leak. I have put 100k miles on 3rd members with RTV and no gasket. Actually gaskets seem to not last as long on differentials. Heck my Ford 8.8 has RTV and it does not leak. All of your 22R(E)'s use RTV from the factory for your oil pan gasket so you can use RTV on your diff or your hubs. I have and not one problem. The key is prepping and cure time. Gaskets will leak once you remove them. If your on the trail and you have to remove a 3rd or a hub, you usually cannot reuse the paper gasket. People think you put on the RTV, bolt the item together and fill it with fluids and your good to go. That is why RTV leaks not because it does not work because you failed to do what the instructions tell you to do.
James
Old 10-15-2010, 02:34 PM
  #43
xxxtreme22r's Avatar
I would like to add something to JamesD's perfect post. The right type of RTV is crucial too. Red RTV is not the Same as Ultra Black RTV is not the same as clear RTV etc etc. The same RTV should not be used on your water pump as your 3rds.
Old 10-15-2010, 02:42 PM
  #44
JamesD's Avatar
You are 100% correct! I forgot to add that.
James
Old 10-15-2010, 02:49 PM
  #45
JamesD's Avatar
Oh and gray and black is the only two I use with great results. Read the TDS (Technical date sheet) PDF under each sealant:
http://www.permatex.com/products/Aut...ket_makers.htm
Old 10-15-2010, 02:57 PM
  #46
ultra-black, red and grey are usually my choices. although I don't use red all that often.
Old 10-15-2010, 04:49 PM
  #47
iamsuperbleeder's Avatar
how are you guys getting charged so much for these gaskets? I got mine from the dealer for like $18 for both sides I think
Old 10-15-2010, 09:02 PM
  #48
TMP
TMP's Avatar
Seriously. I purchased the gaskets from a dealer for $10.
kgcwb44
01-29-2023 10:02 AM
PlayAwhile
07-20-2015 11:36 AM
1996Taco
07-20-2015 12:02 AM
Steven.m.paulk
07-13-2015 01:40 PM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Aisin Manual Hub Gasket or no Gasket
