a340h transmission help
I have an 89 4wd v6 pickup with an a340h trans. The problem I'm having is no forward or reverse unless. If I rev the engine up it will catch and work perfect until I turn the engine off then back to square one. I did change the lockup and 2 shift someone. The only code it's showing is for the vss#1.
http://personal.utulsa.edu/~nathan-b...31diagnosi.pdf
I'm no transmission expert, but a failure of VSS1 shouldn't keep it from going into gear at all. Could be a bad linkage, but sounds a lot like "fried Transmission."
Let us know how it turns out.
Thanks for the reply. If it is fried or an expensive fix I my opt for a 5 speed manual swap. If i get time tomorrow I'm going to go to the transmission shop and see what he says.
Does it still have the problem if you manually shift to "L" or "2"?
When you rev the engine and it works, does it make a clunk noise and all of a sudden work?
From the information provided, it sounds like a sticking shift valve in the valve body being overcome by increased line pressure when you rev the engine.
Yes it was doing it before changing the solenoids. I got codes for the lockup, 2 shift sol
enoids, and vss1 I so I changed the lockup and 2 shift solenoids.
Tried to manual shift but still nothing.
Yes it makes a cluck noise and then works perfect.
If it is a shift valve is this something better left to a trans shop?
Before you condemn a shift valve, it is a good idea to do a manual shift test. Based on the amount of codes you had for the transmission, this is a good idea. Go to this link and it will tell you what to do...
http://personal.utulsa.edu/~nathan-b...33manualsh.pdf
Basically you unplug the electrical connector to the transmission, then shift through the ranges on your shifter. This removes all electronic control of the transmission, thus eliminating it as the problem. If you can get it to shift using the manual shift test, you have an electrical/electronic problem.
so i'm currently swapping a "new" rebuilt a340h into my truck, got my old one filled with water.
I'm a mechanic student, and training to be a trans mechanic. but even i didn't wanna mess with the a340h. if its a stuck valve, probably gonna need a new valve body.
also go to a mom n' pop trans place, not AAMCO or a generic shop like that. they're more likely to throw brake lathe shavings in your oil pan and saying you need a full rebuild. (about $4000 of work)
if you have no forward or reverse, its usually a shift valve. or governor/throttle valve. or your one-way clutch is slipping which is a horrible thing to have slipping...
but like rustypigeon said, check if its not an electrical problem first.
also R&R (just take it out and check it out) is about $800+ so try to get as much info as you can about the problem before taking it to a shop.
the a340h is one of the best transmissions built but they are also one of the hardest to work on (my mentor rebuilt a dozen or so in his carrier)
go to a toyota/japanese import shop as well, not a GM/Ford/Chrysler/European transmission shop. i know it sounds obvious but I gotta buddy that went to a german shop for her engine rebuild on her yota because her neighbor with a benz gets all their work done there... "it was so highly recommended, i don't know why theres still so many problems..."
also a transmission shop will cost you more if you try and take it apart then bring it to them, they won't know if you accidently lost a component even if you didn't. especially automatic trans...
end to end every component in a a340h taken out is about 20-30ft long.
A friend of the family owns a trans shop. I talked to him. I'm gona pull the valve body and take it to him to look at and possibly fix. Now all I need is the time to pull it. Thanks rustypigeon and bruno4turbo for your help I'll keep you posted.
and don't try to take the valve body apart... theres about 5-10 check balls in them (like little door ways for fluid flow) and they're like little bbs that LOVE to roll under stuff never to be seen again... found that out in transmissions class lol.
TheBFA
02-15-2020 06:55 AM
Odin
09-26-2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
kelly1450
09-02-2015 12:29 PM
