'95 4Runner wont run after plenum removal
Hey guys, first post here.
So my 95 4runner blew a hole in the coolant bypass hose on the firewall side of the engine. I removed the Plenum and replaced the hose and now it will not run, it'll turn over and fire, run for a second or two make a backfire sound from the intake and die. I cant for the life of me figure out what ive moved or disconnected that would cause this. Any help is apprectiated. Its a 3.0 3vze(I believe)
For what ever reason it seems the Circuit opening relay is dropping out.
Afm not hooked up or the connector is not plugged in correct bent pin , corroded etc
Enough air is being pulled in down stream the switch in the AFM is not able to close.
A crack in the air intake from taking it off from being old and brittle something else not installed correct.
Ok so what is the minimum amount of vac lines and intake components needed for this thing to at least start and run? Plenum and throttle body? Pcv valve hose? I figure if I can hook up the minimum and work backwards from there. Thanks to those that have answered so far I'll check those things first.
Ok, put big bulky air box stuff back on, with a repair to the flex hose at the throttle body. The truck started but smelled strongly of fuel. Removed air filter hose from throttle body and it was FULL of gas!! Not sure where it came from but something is definitely pouring fuel into the intake, air filter area
Ok, so ive "hosed" it up pretty bad,(pun intended). I had one of the PS lines going to the fuel return!! Got that sorted, not sure how long the PS pump will last though. I need to know where the fuel return line and the AC idle up hoses go. Please Help
Got all the hoses back in the correct places! Whew! She blew smoke for about 10 minutes then cleared up. Anyone know what damage I might have caused? Have I ruined the PS pump?
zd92655
03-06-2022 12:58 PM
voiddweller
19
05-02-2016 09:10 PM
JaredL
06-16-2015 04:47 PM
