90 22re not running good, cannot figure it out
Old 12-11-2008, 08:47 AM
couldbelower's Avatar
Alright heres the deal.
I have a 90 toyota dlx 22re automatic. I have never had any problems with it and the original ac still works. the truck has always had its maintance and everythign works great. in its time i have only replaced a battery, altenator and water pump. that seems pretty good to me for being a 90.
recently i noticed i was getting gas a lot more often and that the idle was higher then usual. sometimes it would idle higher as if i was turning on the ac or somehting but without actually turning it on. then after a little time and not being able to figure out the problem things beagna to get worse.
now at this point i am totally lost on what is going on.
when i start the truck cold, like in the morning after sitting and it runs terrible. it seems like it is running on 2 or 3 cyliners. or almost like it is consistanly missing, or there is a lack of air. its realy weird. you can smell through the exhaust a weird gaseous smell. after some time it will clear out and run fine except for the higher then usual idle. now this issues is different everytime. sometimes it will start up and be fine and other times it will clear up in 30 seconds and other times it will take 10 minutes. then if i am sitting at a light it will miss for a second or 2. it is totally intermitant and is different everytime. but every day it does seem to get worse.
I need some help trying to figure it out. maybe someone on here has seen this before. i cannot totally explain the issue but that is my best description.
Old 12-11-2008, 09:00 AM
99SR5's Avatar
spark plugs might be bad?
Old 12-11-2008, 09:18 AM
874runnersr5's Avatar
try pulling the codes, and post them on here and we can help you even more.
Old 12-11-2008, 04:42 PM
abecedarian's Avatar
spark plugs or wires maybe. maybe vacuum leak. maybe faulty idle air valve under the throttle body.
personally, I'd lean towards either the vacuum leak or IAV being the problem.
Old 12-12-2008, 09:01 AM
I have changed plugs wires, cap, doesnt seem like there is any vaccum leak, i check the best i could and no audible signe of a vaccum leak, it has never thrown a check engine light either, even when it seems to be running on 3 cylinders.
Old 12-12-2008, 09:15 AM
gilby4runner's Avatar
cold start injector?
Old 12-12-2008, 11:28 AM
just a 22re's Avatar
vac leak man i say take a can of brake clean and spray the intake down when its running and the injectors and the vac lines it will tell you for sure and were its at!!€
Old 12-12-2008, 11:37 AM
toyota4x4907's Avatar
Brake cleaner? I thought you were supposed to use carb cleaner..?
Old 12-15-2008, 08:21 AM
I have tried this in the past when the idel issue first came about. i could not find any leak at all.
the truck is not running very good at all. it runs what seems to be like 3 cylinders but i wont stall. this morning it tooka while before it started it seemed like it was running all 4 cylinders. the truck never looses any power which confuses me even more. it sounds like its a diesel or some thing. its weird i dont really know exactly how to explain it.
Old 12-16-2008, 08:48 AM
anyone? anything? yesterday when i went to leave work it didnt even want to start. this is the first time it has done that but after a while it finally started. i am pulling my hair out here. i dont even know where to begin.
Old 12-16-2008, 08:55 AM
is it possible to pull codes even if the check engine light is not on. i dont think any of this has ever caused it to throw a code.
Yont283
09-23-2022 08:06 PM
Spicer
06-10-2020 08:39 PM
91toybeater
12-27-2015 07:46 PM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
XtremeOff-Road
16
06-27-2002 07:32 PM
Quick Reply: 90 22re not running good, cannot figure it out
