89's running propane
blew a huge chunk of rod out the side of my driver side block about 3 days ago. started to tear apart the engine got the head off all is good cept the hole so i got another block. gonna order everything from engnbldr street rv head-261c cam.40 over
going the route of propane this time
so who else is running pane?
LP burns super clean, less damage to the engine over time, but in my area its pretty hard to find propane at the same price of gas. It can be done but its usually industrial supply yards which is less than convenient.
Before you decide to go propane and drive it on the road make sure you have enough places to get fuel (or a large enough store of it at home).
I'd run propane if it wasn't such a hassle to obtain, but its not a very popular fuel outside of industrial yards.
other reason why not since im going to build my new engine from scratch, swap in a 5sp, spool the rear, and hopefully sas. i now have the perfect excuse to sink some cash into the truck. i'll use it to dd when i dont drive my lexus sc400
Does doing propane on an engine originally designed for gas (22re) net better power or better mpg? One of the forklifts at my work has a 4.5L i6 LPG engine, its HP is 96 at the crank.
That engine was designed for torque, NOT hp.
I've heard of farm trucks going well over 400,000 miles on the original rings, pistons, valves, etc etc. And have the oil still look clean after 3000 miles.
Propane combusts significantly cleaner than regular gasoline, and you can tell by the fact that propane has the "hotter" blue flame, while gasoline has a "cooler" yellow flame, with black smoke.
Exhaust gases might be a little warmer, but the main point is that it burns cleaner, resulting in a brighter, bluer flame. With less carbon leftover from the combustion, less carbon gets built up on top of the piston and valves..
coffey50
07-28-2015 10:55 AM
