5.71 gears and 8 inch spool?
I wanna get 5.71 gears for my 91 4wd pickup. I am running 37 inch baggers. I would like to put a spool in my back rear end. Is there a spool out there that will work with the 5.71 gearing?
probably but 5.71 are rumored to be weak due to the pinion being incredibly small. i have heard that only 2 teeth engage on this gear set compared to 3 on the 5.29's. with a locker it might spell disaster for the gears. the spool should be a drop in with whatever gears unless you have the factory 4.88's than im not so sure
Also, make sure you have someone that knows how to install those high performance 571 ratio gears for long life.
http://marlincrawler.com
http://justdifferentials.com
etc
etc
I do know there weaker but I thought with 4 cylinder it wouldn't be to hard on them. I am mostly wondering if the ring will bolt on to the spool. That is the question I should of asked.
That said I wouldn't run anything deeper than 5.29's for strength reasons, prefer 4.10's in a full time wheeler.
i don't believe in the '5.71s are weak' bull****. i punished the living hell out of my 5.71s and they were just fine when I took them apart to extract the locker. let me reiterate, 5.71s with a detroit locker with 35x15.5r15 TSL SX's spinning the crap out of them on slippery rocks and mud. they held up fine. for the record, i had them installed behind both a 22re and a 3vz-e, beat them up on both, and never had a problem anywhere with it, ever. 5.71s are likely less forgiving to half-assed installs than a higher set, but saying they are weak is just spreading misinformation and garbage. mine were definitely not weak.
I'd like to know also. they came in the 4runner when I bought it, and I figured it was probably garbage like the rest of the vehicle so I abused it... and nothing! it came from somewhere here called waimanalo which implies low expectations. so i was pleasantly surprised when the entire vehicle didnt fall apart when i drove it back home
I bought a Spartan locker for my truck and the wife's XJ. I was thinking about a spool, but decided to test the Spartan instead because nobody around here had tried one. I love it for a lunchbox, and it's been pretty tough. Put one in a buddys truck with 35's, and no issues. He beats that truck like it owes him money
spartans are well known up here in newengland! we love them "for a lunchbox set up" just make sure you use the hardened pin and they last a long long time.i will be putting one or two in my daughters truck when i gear it with 529s.already doing the dual case thing.
I have an automatic transmission and i had 33 inch boggers on it before and 4.88 gearing and it still didn't have any power. Whats killing my power the most is my automatic transmission. I was hoping it would of broke on me by now but that darn transmission hasn't yet. So if i didn't have a automatic transmission I would be getting 5.29 gearing for it.
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
08-04-2015 02:08 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
coffey50
07-28-2015 10:55 AM
