3vze: Low oil condition 4 weeks after change...no burning
Old 01-29-2007, 03:41 PM
Rhew Runner's Avatar
Well...all that I have to say is that if you have any oil on the dipstick, then you are in the same boat as most of the older toyota engines and losing a quart of oil every so many miles. Just need to check it every week to keep it topped off if that's the case. That's not a good thing that you let it go so long that you needed 2 1/2 qts.
BTW - check that oil cooler bolt.
Old 01-29-2007, 04:00 PM
ChickenLover's Avatar
Originally Posted by chimmike
Anyone know EXACTLY how much oil is in the system when the oil level is at the L line on the dipstick?
The distance between L and H on the dipstick is only about a quart. If your dipstick is reading L, you have about 4 quarts in the system.
Old 01-29-2007, 06:16 PM
95RunnerSR5's Avatar
Originally Posted by tc
Mine was pretty low last time I had it changed (below L). The oil pressure being low happens on mine too. I'm about 1000 out from an oil change, gonna dump some seafoam in the crankcase and see if it's sludge.
mine leaks a little too and my oil turns dark fairly quickly but there are NO leaks and no smoke! what gives??
Old 01-30-2007, 04:37 AM
chimmike's Avatar
I looked at seafoam yesterday and it didn't look like that removed/broke up sludge. I'm going to drain all the oil saturday and refill. I put some lucas additive in this time around and it seemed to help the pressure thing (also the fact that I added 2.5 quarts of 15w40) I think saturday I'll fill, then drive around a bunch with that seafoam, and then drain again that night.
IMO the lucas is just a thickening agent. If you're worried about low pressure, just run a thicker oil. It'll lube a lot better and prolly won't get by the rings as easily.
I'm more worried about possible sludge, being that it's got 161k on it and I'm not the original 2 owners
Old 02-03-2007, 08:34 PM
  #25
allenr's Avatar
Whats the best way to degrease the engine. My 95 seems to be leaking from the cooler, valve cover gaskets, and rear main. It was leaking bad from the oil filter when I bought it. The filter was so loose, I could wiggle it around so some of the oil on the engine is from that. I am still leaking a quart every few days but cant tell where its coming from because there is more oil on the outside of the engine than the inside.(seriously)
Old 02-04-2007, 04:13 AM
  #26
chimmike's Avatar
I've found that my driver's valve cover rear leak makes it look like I have a rear main leak as well, (which I might but I'm hoping I don't)
Old 02-04-2007, 05:35 AM
  #27
FredTJ's Avatar
If your CEL comes on, and it appears that it has a couple of times, why don't you do the obvious and check for code(s) ???
If you have checked already, what code(s) did you get ?
Fred
Old 02-04-2007, 07:09 AM
  #28
Bumpin' Yota's Avatar
Sup sup chimmike, might want to do a compression check real quick, followed by a leak down. If you are dumping 1 qt in about what 4hrs of drive time, something is wrong...
My 3vze would dump about 1.5qts every 3000 miles but mine leaked from damn near every gasket! lol I bet its getting by the rings and being burned. Either that or the PCV valve is stuck open and you are just burning oil off that way.
but the leak down would let you know if the rings were on the weak side.
Old 02-04-2007, 09:46 AM
  #29
tc
tc's Avatar
Gunk Foamy Engine Brite works great for cleaning it up. (I need to do mine too)
Old 02-04-2007, 01:07 PM
  #30
chimmike's Avatar
I haven't even been able to swap out all the spark plugs yet, let alone do a compression check! lol.
the codes were: EGR and rich condition.
It's more than 4hrs of driving, and what driving it is, is hard trail driving.
Old 02-04-2007, 01:22 PM
  #31
keithguts's Avatar
OK, I alsohave a 3.0 and I had major work done to it. New Valves, HG's, Timing belt, etc. After about 3000 miles, I noticed that it needed 1.5 qt's of oil. Is this normal after have this type of work done to it? Also I have about 145K on it.
Old 02-04-2007, 02:03 PM
  #32
FredTJ's Avatar
Of course it's not normal.
It's not normal for practically any vehicle to burn 1.5 quarts of oil every 3000 miles.
Fred
Old 02-04-2007, 02:32 PM
  #33
CyMoN's Avatar
the gunk gel oil remover is good as well it stays on the motor better than the regular gunk remover.
both work if you fallow the instructions.
Old 02-04-2007, 05:49 PM
  #34
allenr's Avatar
Thanks, I'll give one of them a try tomorrow
Old 02-04-2007, 07:15 PM
  #35
Fred
Unless you own a chevy 8.1L v8....lol They did that off of the lot new!
Old 02-05-2007, 02:34 PM
  #36
For everyone who has another question: START A NEW POST!
You are not going to get your questions answered in a post about something else.
Colington
03-08-2020 09:51 AM
Eggslinger
06-08-2019 03:32 PM
Coreyr384
07-10-2015 11:13 AM
Huntingtruckcletus
07-08-2015 05:26 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 3vze: Low oil condition 4 weeks after change...no burning
