33x10.5 on stock 86 4x4?
Old 12-15-2008, 05:30 PM
zeeth2800's Avatar
Will this combo fit?
Please let me know asap!
Old 12-15-2008, 05:57 PM
Trustyrusty's Avatar
Go ask this on www.Pirate4x4.com they know!
Old 12-15-2008, 05:59 PM
BMC
BMC's Avatar
You should be fine depending on your backspacing of the rim. A littl more information might be helpfull though. Is it a 4runner or pickup? stock 4runners sag a lot in the rear. That might be a problem. stock rims or aftermarket? whats your backspacing?
OH YEAH AND WHAT EVERYONE ELSE IS GOING TO TELL YOU. SEARCH!!!!!!!!
IT WORKS FANTASTIC.
Old 12-15-2008, 06:00 PM
4Crawler's Avatar
Some folks have reported doing that size tire on stock rims. You may find you need an inch or so of lift if you run into too much tire rubbing and can't trim the fenders enough:
- http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old 12-15-2008, 06:39 PM
91FREERUNNER's Avatar
got 33x12.50x15s on some 10" wide wheels and they rubbed pretty bad but a little trim work and they fit fine
Old 12-15-2008, 06:44 PM
SpecialScottie's Avatar
Another poo poo thread
Old 12-15-2008, 06:45 PM
sa51's Avatar
but yes,in regards to the first post, though i know i've answered this before, 33x10.5s should fit nicely on an 86, albeit some slight rubbing on your pinchweld at full stuff/turn
i also just noticed my 33x10.5s rubbed my idler arm when i was out berm crawling saturday, but i had my suspension maxed out at full turn
Old 12-15-2008, 10:43 PM
NYChopshop's Avatar
It'll rub a little, I say get new longer shackles and it should take care of itself. 33x10.5s should fit pretty well except in the most extreme of situations. Some people even go 33x9s in the snow. A lot of members will slam you for not searching before you started another thread on the same issue. This, to say the least, has been discussed before. If you read up on the forum rules, you'll see that you're literally responsible for trying to find another existing forum before you start your own. Welcome to yotatech.
Old 12-15-2008, 10:47 PM
algranger's Avatar
they will fit you just need to trim and bang. i had a stock 86 that i put 33x12.5's on with a little trimming and banging
try a search next time.
Old 12-16-2008, 01:34 AM
annoyingrob's Avatar
Yeah, the wheel and tire section has lots of threads, and pictures of 33x10.5s on stock IFS trucks.
RatOmeter
10-22-2015 03:17 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
1994toyota
07-17-2015 03:03 AM
garagespace
07-09-2015 08:37 AM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: 33x10.5 on stock 86 4x4?
