33's and a '91 Runner Auto... Gears?????
Old 03-13-2007, 08:21 PM
AuburnRunner's Avatar
I've got my LC coils and BJ spacers installed already... My runner came stock with the 235's ( I think) not the 31's, and no tow package. Anyways I am putting some 33 X 10.50's on it and I am about 70% on the highway (Atlanta) and need to use the O/D. I am trying to decide what gearing I need. I have talked to people running 4.88's but they say that the power is sh** at high speed... I want to run about 70-80 on the highway. So right now I am looking at 5.29's. Is this the right gear? Also I found this on ebay:
http://cgi.ebay.com/ebaymotors/TOYOT...spagenameZWDVW
will this 3rd work for my runner's rear axle even though its a 4cl? Whatever I do I will need to run a locker. Thanks everyone.
Old 03-13-2007, 08:33 PM
yotasavg's Avatar
i think it'd work, but the price seems too high.....not sure tho.
Old 03-13-2007, 09:10 PM
yotasavg's Avatar
i'm wondering too what gears i should get. if i need new ones. i have 4.88's now.......i wish someone would respond to us!
Old 03-13-2007, 10:08 PM
faubrunner64's Avatar
i have been hearing that if you want to maintain overdrive, witch mean that we have to be cruzing in an rpm rang with some power so above 3000rpm and 3ith 33's 5.71s would be the best way to go being at 3100rpm at 75mph according to a calculator that someone used to tell me this info.
https://www.yotatech.com/forums/f116/5-29s-w-34s-104805/
Old 03-14-2007, 05:55 AM
tc
tc's Avatar
Yep - manual transmission 33's = 4.88
Auto you could MAYBE do 5.29's if where you live is flat, but if you want to be able to hold the overdrive, then I think 5.71's would be better.
My truck is 33's, manual, with 4.88's and it is at 3000 RPM at 70MPH. My g/f's truck is on 35's (SAS), auto, with 5.71's and it won't hold the O/D on anything remotely uphill or with a headwind. She's at like 2200 RPM at 70MPH IIRC.
Old 03-14-2007, 06:10 AM
UKMyers's Avatar
Search before demanding that someone answer you. This very subject has been discussed a zillion times if not more on here.
Stick 33's =4.88's
Auto 33's = 5.29's... many prefer lower.. 5.71's are getting hard to find. None of the wheeling crowd wants them because the pinion gear is so small and tends to snap in half during hard wheeling.
I would steer clear of used junk when it comes to gears. Buy a set of high quality ring and pinions, a good master install kit and have somebody that really knows what they are doing set them up. Regearing is not cheap.. period. I have $2000 into my current front and rear thirds alone. I spent $1200 the last time I regeard to 4.88's. If you can't afford to do it right my suggestion is leave you truck alone.
Old 03-14-2007, 06:13 AM
jfreisner's Avatar
I have the same setup w/ stock 4.88's. I'm going with 5.29's after my SAS because I'm keeping my 33's. I live in Kansas so everything is flat as hell.
Old 03-14-2007, 07:53 AM
i herd that the pinion is not any weaker with the 5.71's is in fach has larger teeth due to the fact that there are less on here?!?
Old 03-14-2007, 09:50 AM
tc
tc's Avatar
Interesting how everyone says 5.71's are weak because of so few teeth on the pinion, but that 5.29's are OK.
Both have 7 teeth on the pinion.
IMHO, 5.71's have got a bad rap because of bad installs. The lower the ratio, the more critical the install is. There's a HUGE difference between 4.88 (8 tooth pinion) and 5.29/5.71 (7 tooth pinion).
http://www.gearinstalls.com/410suck.htm
Old 03-14-2007, 10:56 AM
mt_goat's Avatar
https://www.yotatech.com/forums/showthread.php?t=104805
Yeah that was me, I can also tell you firsthand (since I ran 5.71s w/33s and a 3.slo auto for about 45,000 miles) you will love it.
A few things to keep in mind:
A 33" mud tire will become a 32" tire well before its bald, so if you're the type that runs a tire until its bald maybe the 5.29s would be better. Also some brands of 33" tires aren't really 33" to start with, so measure the tire height and check it for yourself.
Old 03-14-2007, 12:09 PM
sure was mr. goat thats for the info! i have 32's with 4.88's and im only pleased with it on flat with no wind. what is it like havin 32's with 5.71's? i didnt quite figure out that calculator you sent me.
Old 03-14-2007, 01:49 PM
mt_goat's Avatar
32" with 5.71s and the A340H tranny shows 3193 rpms at 75 mph.
http://www.grimmjeeper.com/gears.html
The calculator is easy once you use it a time or two. Just select the "A340H" from the list of trannies already programed in (there is a drop down list where it says "enter your own numbers") On step two select "Toyota with 2.66 low" The rest is obvious except you need to re-hit the calculate botton after every change.
Old 03-14-2007, 03:48 PM
Hey goat... thanks alot for all the info.
I NEED $
Old 03-14-2007, 04:33 PM
big_blue_goat's Avatar
4:88 yukons. Get 'em cryo'ed by bobby long though and use a solid spacer. Trust me you can't go wrong. And you shouldn't drive over 70mph anyway, it's not a great idea in a truck that's geared for four wheeling and big tires
Old 03-14-2007, 05:51 PM
3193 rpms at 75 mph sounds perfect to cruse and still have the power to hold overdrive i think whe i do regear im getting 5.71's
Old 03-14-2007, 06:12 PM
Yota Tony's Avatar
PORC is selling front and rear gears with install kits for $399 IIRC.
4.88 or 5.29.
Old 03-14-2007, 09:43 PM
elripster's Avatar
I have 4.88's and 31's in my A340H runner and I would suggest the 5.71's for 33's. I won't run a 32" tire with 4.88's on this truck. I live in San Diego and it is most definitely not flat here. That coupled with high freeway speeds demand the lower gearing.
Frank
Old 03-15-2007, 04:06 AM
Sorry that I dont know this... I probably should.. Who is PORC?
Old 03-15-2007, 05:50 AM
tc
tc's Avatar
Performance Off Road Center
Talk to Alex when you call
voiddweller
19
05-02-2016 09:10 PM
vasinvictor
01-20-2016 12:39 PM
Ichneumon
09-27-2015 04:21 PM
ACZR
06-23-2015 07:55 PM
Quick Reply: 33's and a '91 Runner Auto... Gears?????
