22re wiring + cranking problems
Old 06-28-2011, 09:14 PM
little_blue_beast95's Avatar
Question 22re wiring + cranking problems
I am currently having problems with my 95 toyota pickup 4wd 22re. I recently encountered a blown timing chain cover gasket. I disassembled the motor myself and put an entire engine gasket set back in place of all the old. in the process I did had to reset the timing chain, which I may not have fine correctly even although I did follow the Haynes manual step by step. Now with the motor complete again the engine with turn over several times and then stop abruptly and then start turning over again; however, the engine still will not attempt to crank. This is one of two problems that may or may not be related. After attempting to start the engine, I have a ground wire that shorts out and turns cherry red. I have replaced the wire twice already only to get the same result. This ground wire branches out from the harness directly beside the breather box and bolts to the body of the truck, then returns to the harness bundled with the alternater wires and then bolts to the motor. I am aware that the root of my problems are my own fault but I lack the ability to pinpoint where I messed up at. Any help will be greatly appreciated.
Old 06-29-2011, 06:47 AM
cody o's Avatar
It sounds like your basic and/or ignition timing is off. This would put a lot more strain on the starter, causing it to draw more current than it normally should, causing the grounding strap to heat up. Make sure your basic and ignition timing are correct. Also, make sure you didn't forget to connect a grounding strap somewhere else. Maybe add one or two of your own, couldn't hurt.
For the love of pepperoni pizza, if your grounding strap is bright red, imagine what your starter is going through!
bigjstang
08-25-2021 12:41 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
toyota32
07-06-2015 05:42 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: 22re wiring + cranking problems
