22re engine trouble
Old 05-17-2016, 06:37 AM
claiby's Avatar
22re engine trouble
Hoping someone might have an answer to this. My truck sputters and loses power when driving. I guess as I reach around 3k rpm it starts sputtering, then when I let off the gas it will smooth out. I have found that moving the distributor a bit helps, but only for a short time. My timing light just went out and have not had time to replace. I have continued rotating the distribute when this happens and it runs much better but then the same issue comes up again. People have suggested the timing chain. Anyone have any ideas on this?
Old 05-18-2016, 07:08 AM
osv
osv's Avatar
the timing needs to be set correctly and then left alone.
Old 05-18-2016, 07:10 AM
Austin148's Avatar
I would start off by correcting the timing per the manual. Then replace the plugs, wires and fuel filter
Old 05-18-2016, 03:07 PM
wallytoo's Avatar
sounds like it could also be fuel starvation, and what you are experiencing is "lean misfire". do you know what your fuel pressure is? it should be around 29 to 35 psi under hard acceleration. if it is significantly lower, it won't run correctly. i've been there chasing it, and at least now, with a good fuel pressure gauge installed, i can diagnose/eliminate fuel delivery/etc by looking at the reading.
wally
Old 05-18-2016, 07:11 PM
claiby's Avatar
wally
I was beginning to think it might be my fuel pump acting up. It is as if it is running out of gas. I will check the fuel pressure and also get the timing squared away. I started thinking about it today and realized it is acting like it did when my alternator went out. Don't thing the fuel pump was getting enough juice to push the fuel. I will check that. Does that explain the improvement when I adjust the distributor though? It runs great for about a week every time I do that.
Old 05-19-2016, 02:31 AM
wallytoo's Avatar
probably only coincidence. the pump can fail various ways: sudden; intermittent; gradual; etc.
Old 05-19-2016, 04:15 AM
Flash319's Avatar
Check your tps and wiring. Sounds like fuel cutoff if it is at the same rpm all the time. Check the wiring at the ecu for water.
foggybottom
05-16-2016 02:56 PM
muddlover
05-14-2016 07:52 PM
weathernaut
05-08-2016 03:32 PM
gyoas759
05-04-2016 09:43 PM
durney
04-20-2016 11:08 PM
Quick Reply: 22re engine trouble
