1991 toyota pickup. BRAKE! light on dash stays on
Old Jun 24, 2015 | 08:08 PM
Aleeex_u's Avatar
Hey guys, I just recently had an issue to when I accelerate, the BRAKE light on my dash comes on on my 1991 toyota pickup. It only came on when I accelerated. But a few weeks later, the light wouldn't turn off. I searched this problem up and people said that it was an indication that my rear brakes where bad. It just stared squeaking, so I changed it. I replaced the drums, shoes, and most of the hardware. But when I released the parking brake, the light was still on. Anyone know anything about this? Thanks guys.
Old Jun 24, 2015 | 08:18 PM
millball's Avatar
Master cylinder is full??
Old Jun 24, 2015 | 08:19 PM
YotaWoRx's Avatar
Ur front pads are prob just about done. The cylinders are taking a lot of brake fluid volume due to excessively worn pads. Check the pads, check the fluid level
Old Jun 24, 2015 | 08:20 PM
Aleeex_u's Avatar
I checked. It's right in the full mark.
Old Jun 24, 2015 | 09:11 PM
Odin's Avatar
"IF" it's full that narrows it down to front brakes- And check out this thread, there's some brake light troubleshooting on the thread that may be helpful. https://www.yotatech.com/forums/f116...sensor-285144/
Notice how the person having problems said his fluid was full and then...
Old Jun 24, 2015 | 09:23 PM
Aleeex_u's Avatar
Notice how one person thought it was full and then...
There's some troubleshooting on that thread that may be helpful.
Thanks. I'll see if there's something I can find.
Old Jun 24, 2015 | 11:23 PM
wyoming9's Avatar
Red face
Sounds like to me you have a bad switch in either the master cylinder or the emergency brake switch.
either one could always be in the closed position
pinched wire in either circuit would also cause the light to stay on. If it allows the the circuit to close
Old Jun 25, 2015 | 02:30 AM
Aleeex_u's Avatar
Do you know which one exactly to pinch?
Old Jun 28, 2015 | 08:58 AM
bpealer's Avatar
Look under the dash and make sure the ebrake is engaging the switch to turn off the light. Mine sort of rotated and wasnt contacting the switch all the time. Light would go on and off while driving.
Old Jun 28, 2015 | 09:40 AM
Team420's Avatar
What he said ^
Old Jun 5, 2016 | 06:52 PM
Daniel Yedinak's Avatar
Wiring Malfunction
So I had this same problem with my 91 Pickup and I let it go on for far too long. Finally it became a problem where I stalled out and when I looked further into it, turns out it was the alternator along with a poor battery connection.
zd92655
Mar 6, 2022 12:58 PM
Gamble_STi
Jun 27, 2015 07:54 PM
GorgeRunner
Jun 27, 2015 07:01 AM
94hiluxZE
Jun 22, 2015 10:42 AM
ItsAtoyotaLIFE
Jun 21, 2015 11:45 AM
